Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
Need a manuel for L17LCD2
Menu will not allow me to stop the flicker and brighten screen
1 Related Answer
Anonymous
  • 624 Answers
  • Posted on Mar 14, 2007
SOURCE: screen displays vertical, but I need to rotate it back to horizontal
Helop, If your screen image is rotated to the rotated to the right or left and you?re asking how to get it back to normal it depends on your system. For Windows while holding the Ctrl and Alt keys down press the up arrow button. If that doesn?t work then your video card driver probably has a component that controls this function. Let us know what your video card make and model is and what software driver for it you have installed and we?ll try to help figure it out. If I?ve misunderstood your question please elaborate.
Our Sony Tv RMyD003 screen is darker than we would like and we need to brighten the picture. We are unable to locate our Manuel and would need your help. Thank you
Try going to your menu or input select and you should see a scale to darken or lighten input. The remote should have a button on it to let you get to main menu.
1helpful
Can I brighten the picuture my goodmann tv without a remote control
As there is no Menu button on the frnt panel of your TV, you can't do any picture adjustments, without its remote control.
Ive had my ematic mp3 player for 2 days and now the screen just barly glows but you cant see anything.And you can still here music
ok well when you can see the menu the best go to options then to display then there should be an area that allows you to brighten or darken the screen turn it up then it should fix the proublem
1helpful
Can't brighten, menu brightness all the way out+++++
you need to open your tv,s back cover then manually adjust the screen grid from the flyback transformer,note to adjust it slowly and be sure not to over adjust
Hey listen i owned ur Liquid Video L17LCD2 (Silver) 17 in. Flat Panel LCD... and i had it for like 3 months and im haveing the same problemas everyone else it flickers on and off then i can see the screen...
There is no "instant" fix for this problem. A friend of mine gave me this same monitor 3 months ago & I just sat down to fix the unit. Here's what I did: http://www.wizardanswers.com/liquidvideorepair.html
I followed the exact steps & about $5 later I have a working monitor.
MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
2answers
Unlocked e-machines 17f3
It depends on the monitor, but try holding the Menu and Right arrow button together.
Screen displays vertical, but I need to rotate it back to horizontal
Top Liquid Video Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
