Beta87 handheld uc2-ub wireless system had for years.Problem began with occasional almost no vocal sound and static when mic on,amp up.Receiver reads full RF signal,-18 on the audio.Problem is now constant
SOURCE: Hi - I have a
Hi, make sure the signal flow from the amplifier through the process to the speaker has sound coming out from it..
Also are you familiar with SM 58 mic,how to mute and unmute the mic?..the color of the lightthat shw and what they indicate.
Green light ----mic on.
Yellow -----mic mute.
If after all this, Not sound, that means you will need to use a meter to
read the mic itself by opening up the mic from the head (cone
area).Unscrew and remove the cone test connections inside setting it at
continuity on the meter..
If found that some of the connections are not working, then the mic is gone..You will need to replace it with another...
Note,, SM 58 mics,also get damaged fast..not to strong for rugged
works..And you might end upbuying a new mic..But make sure you don't use
SM 58 again, Change to something else..still contact your repair man...
Take care.
Take care...
SOURCE: Have Shure T2 Wireless transmitter - no audio - can fix?
There is a company in Chicago that can still repair old Shure wireless. Delta Audio 877-764-3634.
