Machine is at least 12 yrs old
SOURCE: My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
SOURCE: Brother Intellifax 770 - can not fax out
You probably need a prefix to dial out of your office. If it's a home fax machine, you may need to dial the number "1" plus the phone number you wish to dial.
SOURCE: Black pages
Try to copy a document. If the copy comes out black then the the
scanner is dirty. Clean the scanner glass (products on the market that
clean by sending through the scanner) and try to copy again. If after
cleaning the scanner, the copy is still black you have a scanner issue
and the laser/scanner unit will need replacement. Best of luck and
please post back with any questions or just to rate the solution.
Greg
SOURCE: Brother Intellifax 770 - how to connect to PC?
The intellifax-770 deffinetly cannot connect to a PC. There are several other models that can, but not this one.
