Question about Dell PowerEdge 840 (becwmk1_2) Server
Dell PowerEdge 840 blinking orange light
Blinking Orange light
3 Related Answers
Anonymous
SOURCE: dell poweredge 830 server orange flashing light
its the cover switch. there is a small push switch on the front panel that detects if the front cover has been removed, either the switch is defective, or the cover is not seating properly to close the switch.
Posted on Sep 30, 2010
Anonymous
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
Posted on Dec 09, 2007
James Keener
  • 103 Answers
SOURCE: Poweredge SC 1420 won't come
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Posted on Aug 17, 2011
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Tip
Printer error (orange or blinking light)
<b>Printererror (orange or blinking light)</b> After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
on Mar 31, 2011 | Office Equipment & Supplies
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
N300 router has a steady orange blinking light
The blinking orange power light suggests that there is a problem with your modem. The modem should be plugged into the top ethernet port of your router. Try turning off your modem for 10 seconds and then turning it back on.
Dec 07, 2012 | Belkin Computers & Internet
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
Sep 09, 2012 | NetGear WNDR3300-100UKS Wireless Router
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Stand by light blinking orange, tv won't come on
stand by light blinking orange and the TV won't come on
Aug 31, 2008 | Samsung LTN1535 15 in. HD-Ready LCD...
Dell PowerEdge 840 (becwmk1_2) Server Logo
3,555 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
