Question about Nikon COOLPIX S52c Digital Camera
Nikon coolpix s52c lens cover error
Baically, i went to an old abandoned quarry full of sand and my camera got some sand in it and at first the lens kept getting stuck and i had to keep pushing it open/closed. now it does not open or close at all. i have tried taking it apart and the lens is free to move but still doesnt move and still says lens cover error on the screen.
Posted by george kirkham on
5 Related Answers
Anonymous
SOURCE: coolpix s6 lens cover error
This may be related/helpful since lens mechanism possibly same as S3: My S3 in normal home use (no sand, wet or shock) just now displayed the Lens cover error message, with cover only half open. Using a tooth pick I eased it gently and it popped open, took a few trial pictures, and changed settings etc, seemed fine, but lens cover would not fully close unless eased. Now will open and close slowly on its own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as though part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Posted on Sep 25, 2007
Anonymous
SOURCE: Lens Cover Error- Nikon CoolPix S6.
i have the same problem, but what i do is turn it on then off and then i pull on the lens a little to get it to go in all the way and then i turn it back on and it works
hope it helps
Posted on May 08, 2008
Anonymous
SOURCE: Nikon S200 Lens stuck inside
I had the same issue with my S210, so after reading other people's advice to send it in to Nikon and since that was going to probably cost me as much as the camera itself I figured it wouldn't hurt to try a little something. The lens on mine was a hair off center or had been pushed in on one side (barely - looking at yours you may be able to tell which side) - mine was in my purse also. So, I took my handy dandy skinny prying instrument (normal kitchen butter knife) took the battery out to make it try to open again, then when I popped the battery in as the lens tried to push out I pried the side I thought was a little lower back towards center...I heard a little pop and it worked! The lens came all of the way out and it's all good.
So, use gentle hands and try if you want, but don't think I warranty this!
Posted on Mar 07, 2009
Anonymous
  • 300 Answers
SOURCE: my 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Posted on Jul 31, 2009
Anonymous
  • 11967 Answers
SOURCE: camera's lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Where can I obtain a service repair manual?
[PDF]User's Manual
cdn-10.nikon-cdn.com/pdf/manuals/coolpix/S52_S52c_EN.pdf
provided with your Nikon product are trademarks or registered trademarks of ... only with the COOLPIX S52), or by ... accordance with the instructions, may.
User's Manual - Coolpix S52 / S52c ' Nikon Knowledgebase
https://support.nikonusa.com/.../users-manual---coolpix-s52-%2F-s...
NikonApr 21, 2008 - Nikon Coolpix S52 / S52c - User's Manual. This guide discusses features and usage of the Coolpix S52 / S52c Digital camera. Image ...
COOLPIX S52 from Nikon
www.nikonusa.com/en/nikon-products/.../coolpix-s52.html
Nikon3 days ago - New EXPEED Image Processor ensures high-quality pictures with stu
Nikon Coolpix S52C camera transfer pictures problem.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
3helpful
Nikon coolpix lens error
Hello Ken,
The lens error in many cameras are caused due to sand or grit interfering with the lens extension mechanism. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials stick to the camera by electrostatic build-up from the camera rubbing against the side of the carrying case. To resolve the lens error remove the battery for some time. Then insert the battery again and charge the battery completely. Then try pressing and holding the Menu, Function, Function Set, or OK button while turning the camera on. Also try the factory reset option. Also try the on/off button many times after battery full charge.
When I turn off my CoolPix S6 the lens would close completely. When I turn on my camera the lens is completely open and the screen just says lens cover error.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
When turn my camera on (Nikon Coolpix S6000 I get a Lens Error!
Hi, usually caused by a lens jam or sand/debris getting into the lens mechanism. Lens
replacement will probably be the best solution for permanent results.
How can I fix my camera when it has a lense error?
This is probably THE most common single failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
I got sand in the lens of my Nikon Coolpix L14
Take it in to be serviced. Or junk it and get a new L20 or something similar.
How do I fix the red eye on S52c
You can download the manual from
http://support.nikontech.com/app/answers/detail/a_id/14559
1helpful
4answers
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Nikon COOLPIX S52c Digital Camera Logo
Top Nikon Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Nikon Camera Expert? Answer questions, earn points and help others
