"Is there an easy solution to repairing corrupt system files in windows 7 64 bit?" What I mean is when you perform a System File Check in the command prompt you get a error that windows found corrupt filse but was unable to repair them, my question is are there any solutions to this problem other than doing an upgrade or clean install? I've tried system restore, but the files are stll corrupt and also tried to create an image file, but Windows doesn't recognize the image. What can be done to resolve the corrupt files issue?
Try the chkdsk utility by running command prompt in Administrator mode ("cmd" in the windows search bar, right clicking to "run as administrator") and then typing "chkdsk /f" into the prompt, and following the instructions in the window. Then you just restart the computer. Hope this helps.
You have done everything I would have suggested, at this point a clean install of your operational system is the only real option to remedy this situation.
Testimonial: "Thank you for your help, guess Bill Gates never meant for us to be able to do a repair. Tony"
follow the link given below from MS knowledge base:
http://support.microsoft.com/kb/307545
Hope this resolves the issue.
Your feedback is appreciated.
Askari :)
SOURCE: windows failed to load because the system registry
Do a system restore to a time before any thing went wrong. Otherwise here is a step by step way ti fix it all up. at the link below. http://support.microsoft.com/kb/307545
SOURCE: Windows fails to start. Startup repair is unable to repair.
insert a WinXP Cd in the CD rom drive and restart and let it boot from the disk, let it install the OS again...format the HD (u will lose all data there but ur machine will come back)
SOURCE: netbook acer aspire one Windows could
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
You can also schedule a run of the chkdsk utility, which fixes a lot of errors like these by typing "cmd" into the windows search bar, and then right-clicking on the command prompt icon and clicking "run as administrator" After you have done that, type "chkdsk /f" into the prompt. Follow the directions in the prompt, and after you have scheduled it, restart your computer.
