Started to wash load and then stopped at 1min to go and flashed f21 and now nothing ids happening
It is
possible that the machine does not start off the cycle because there are errors
due to feedback from the inputs. For the program to start up the main program
controller must initiate the INLET/MOTOR/DRAIN
pump/ valve to open up and allow each function to be driven starting from
the flow of water into the drum as also the drain valve to open to exit the
water at the point of the program cycle. If this does not happen then the
voltage at the valve/motor/pump must be checked or the fault relates to no
voltage from the controller. This means
the controller is a suspect. If the
water flows then the flow should be good, if not the inlet valve is bad or
there is dirt in the filter. Also check the flow at the inlet of the water
line. Once the water comes into the system the WATER LEVEL SENSOR - normally a
pressure switch- must activate at the preset/chosen level to give the signal to
the program controller to switch on the motor. What is most important for the
motor to start functioning is that the door switch must be ON when the door is
shut or this will be an error for starting the motor for rinse and wash. Check this
link to replace the inlet valve: Finally
after the wash the drain valve will be activated, the water is allowed to come
in to rinse and then finally the dry spin with the drain valve/pump activated
so as to drain off all the water from the clothes during the spin. Make sure
that a fault in any of the cycle will relate to the specified action, so check
the command from the program module and then the executing device be it the
valve or motor or pump. Please check the link below: http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
SOURCE: f 21 flashes
We have the exact same washing machine, and the same problem. we will need to lift the front of your washer up and undo the bolts to the front cover. you will see a white round turn nob, this is the filter unscrew it (you kight plug your nose) and empty all contents, replace, screw the front plate back on and you are good to go!
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
SOURCE: what is the error code f21 means on a bosh
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
Whilst holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code.
SOURCE: BOSCH 1200 EXPRESS CLASSIXX ALL RINSE SPEED
bunged up theres a new word does that mean that you took off the pump and cleaned out the hoses as well as the pump yet the lights are still flashing on your unit please message me back with your answer and any further questions you may have thanks again Rick
p.s this also would mean you have cleaned the drain hose line that goes from the pump to the outside of the machine and tested the line to assure that water is flowing out of the drain line in a steady stream of water I await your reply Rick
