Question about Canon PIXMA MP495 InkJet Printer
Scanner gives me code 5,145,61 how can fix it ?
Can't scan just gives the code, everything is hooked up the Lan cable
Dino B
    New Friend:
  • 3 Answers
RE: Scanner gives me code 5,145,61 how can fix it ?
I was using wireless router and receive exactly the same error code as above.
SOLUTION: Turn-off printer/scanner; reset or turn-off the wireless router power and then turn-on again. Turn-on the scanner. Start scanning.
Posted on Jan 24, 2014
4 Related Answers
Anonymous
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
Robert Kitaji
  • 1335 Answers
SOURCE: Scanner was working fine this
Check the scanning unit by copying something on the platen. If this does not work, you have a defective scanning system. If it does work, check connections between the PC and the MX870.
Please let me know if this works. If not we can investigate further. Thanks.
Posted on Feb 24, 2011
linwave
SOURCE: I am trying to scan
Your firewall block the communication. You will need to get into your protection software and allow 'full' access of MP Navigator (EXT)
Posted on Sep 11, 2011
SKEzell
  • 25 Answers
SOURCE: Scanner is disconnected or Turned off.
Try going to manufactures web site and downloading drivers for the printer from there. Also you might check your device manager to see if the unit is being recognized by your computer. it should show up iunder USB or Printers. I had an Epson that did the same thing but mine was a wireless and I had to re-establish coneection and go through setup again to have my IP address recognized. Most of the time plug n play will pick up the new device.
You might also try running security and windows updates on your computer, there might be an update that is keeping the computer from recognising the printer anymore.
Its just a start of what could be going on, hope its an easy fix.
Posted on May 29, 2012
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
Cannot scan with Canon MX870. Error code 5,145,61 Windows XP Wired LAN connected printer and laptop reinstalled Print/scan/fax S/W - still no scanning. Printing OK. ???
My solution was to open the MP Navigator application and then click the preferences at the top right. There is a product name dropdown. In my case the incorrect MAC address was chosen (denoted by "Network:XXXXXXXXXXX"). Once I chose the other address it worked perfectly.
Jul 15, 2012 | Canon PIXMA MX870 Wireless Office...
May 29, 2012 | Canon PIXMA MP495 InkJet Printer
My cannon MG5220 printer will not scan but prints fine. i keep getting an error that says "cannot communicate with scanner for these reasons: -scanner is turned off. -scanner is disconnected (It is...
Many printers will not scan over a network, even when they are supposed to. Try connect to it with a standard USB cable and scan to PC directly. If that doesn't work - you have probably got a faulty scanner.
If the scanner works OK directly to a printer, then your issue is either LAN/WLAN bandwidth or an unstable IP address. Try fixing the IP Address rather than running DHCP address allocation eg set it at 192.168.x.150 where x is the range value for your network. Then set the printer port address on your devices to the same values and try again.
Nov 27, 2017 | Canon PIXMA MX870 Wireless Office...
I am trying to scan a document using the Canon PIXMA MG6120 that is connected via wireless LAN to my laptop. I get an error message on the laptop as follows: START OF ERROR...
Aug 03, 2011 | Canon PIXMA MX870 Wireless Office...
I just got aWBR2310 router with no hook up instructions how do i hook it up to my modem
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
After configuring the wireless card in your laptop/computer with the D-Link's wireless settings then,
remove the LAN cable from the computer and D-Link then connect the LAN cable to your DSL or cable modem then connect the other end of the LAN cable to the D-Link's WAN or Internet port.
You can now surf the Internet using the D-Link wireless connection.
Apr 14, 2011 | Computers & Internet
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Hi
I had the same problem, at first I thought that it was the original drivers (the ones I got with the printer) so I donwloaded the drivers from the canon website, this did not resolve the problem. What I also tried and it worked for me was connecting the printer to the computer with it's original usb cable. I bought a couple of weekes ago a usb extension cable (about 5 m long). With this extension cable I can print but I can't scan any document, it just gives me the same error. Hope this works also for you.
Bye
PS: My printer is a Canon Pixma MP190
Sep 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP495 InkJet Printer Logo
7,212 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
