Question about HP LaserJet 4730 MFP Printer
Hp 4730 fuser reset
Need to reset 4730 fuser unit
Posted by nick908 on
Prajeesh Prajeesh S P
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
How can reset replace fuser kit error hp LaserJet mfp 4730
Posted on Jul 16, 2018
Raj Kumar
    New Friend:
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
Posted on Mar 05, 2014
  • Raj Kumar
    Raj Kumar Mar 05, 2014
How can i fix 50.0 fuser error on hp printer p1102
pull power out of printer
release fuser unit from back of printer
and check it is not fused together
The fuser unit may may need to be replaced
Jan 27, 2017 | HP LaserJet Pro P1102W Printer
HOW DO I RESET THE TONER IN HP 8690 MFC AND RESET LAZER AND FUSER
You dont need to do that because even if the machine asks for replacement, there is no need. The machine will still work until the parts are damaged physically and in that case you have to replace only Fuser and the Tachnician will reset it. Laser you need Never to replace. Toner resets itself every time you change it
Oct 01, 2014 | Brother Mfc-8690dw All-in-one Laser...
Hp cm4540 how to reset fuser unit
When you replace the fuser unit it will reset automatically
Aug 24, 2014 | HP LaserJet Office Equipment & Supplies
HP Color Laserjet 4730 MFP scanner not initializing
open the scanner's glass cover ,,, there is a white sensor on the backside of the glass ,,, clean it with a little wet fabric ,,, then change the scanner unit's place to be exactly under the sensor ,,, close the cover ,,, turn on the power ,,, and give me a good rate ,,, :)
Sep 22, 2013 | Office Equipment & Supplies
How to reset fuser unit in printer hp laserjet 4250
turn the printer off for at least 20 minutes, then cycle power. If the 50.2 fuser error occurs again, you may need to replace the entire fuser assembly OR you will need to replace the power supply.
Dec 24, 2012 | HP LaserJet 4250n Printer
Printer keep says replace fuser kit
These is a part on the fuser called a fusable link that blows the first power up cycle and resets the replace fuser message. It sounds like the fuser you installed is a remanufactured unit that was not professionally rebuilt. Contact the place of purchase and get a replacement. The message can only be reset with the fusable link on the fuser.
Feb 13, 2012 | HP LaserJet 4700 Printer
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
I have a 50.2 fuser erro on our Color Printer HP 4700
The 50.2 code on nearly all HP laser based machines including your 4700 means you have a fuser error. The fuser unit is the assembly that heats up and "fuses" the toner onto the paper. There are a few things you can try including, power cycle the printer and see whether the code resets or try reseating the Fuser Unit. Neither of these will resolve the issue in most cases. Most of the time fuser unit replacement is necessary.
Here is a link for you to see pricing and a picture for your fuser unit. You may want to just buy your own fuser and replace it if your are mechanically inclined. If not you can have a local printer repair shop replace it for you. At least they won't rip you off on the price of the fuser unit. Note that there may be some cheaper prices out there on this unit.
http://www.precisionroller.com/search.php?q=hp+4700+fuser
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | HP Color LaserJet 4550hdn Printer
HP LaserJet 4730 MFP Printer Logo
747 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
