My JVC DR-MV7 DVD VCR RECORDER /PLAYER shows " No disc' on the tv screen so it was cleaned over and over condition continued to worsen and finaly would not play a disc and "no disc" was always the message. Disconnected and put inthe garage for a time and it played once and then the same "no disc" occured overe and over. What is the fix for this issue? Thank you!!
SOURCE: dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
SOURCE: JVC DVD Recorder Problems DRMV7
you can do the following to try and salvage it.
1) insert a cleaning disc, even if it doesn't read the disc the brushes should hit the lens a few times while it is trying to read, do this 4-5 times or until the disc reads.
2) if that fails (even if it doesn't fail) open up the case and use canned air to clean the components, these units are dust magnets.
3) i believe this unit uses a hitachi drive, once you have the model of the actual dvd drive, you should be able to order a replacement if it is indeed bad.
9 times out of 10 it isn't the firmware thats failing, it's either the lens assembly losing alignment, or bad dust accumulation, other than that, sometimes the boards fail on the dvd drive itself, so replacing it usually clears up the issue.
hope this helps,
trin
SOURCE: My JVC DR-MV7 will play
My JVC DR-MV7 will not accept any disc for playback. I insert a movie disc and it consistently rejects them. After about 15 to 20 attempts, sometimes it will stay and begin reading the disc. It also sounds like some internal components are encountering some resistance (moving parts inside?). Any ideas?
SOURCE: Unit will not record DVD's
remove cover clean burner eye a little toilet paper,put a little grease on linear bearings, very little using a toothpic use verbatim dvd rw discs from cdw inc. 1x4 speed
SOURCE: new dvd will not run
I learned too late to NOT try and do anything fast with this or any such machine. Wait very patiently for the results of the button you just pushed. I'm suffering for my impatience with the same unit. However, you can try this. Mine says it cannot read the DVD-- whether store-bought or one I made. I have gotten it to play by hard-starting the player. Press and hold the On-Off button on the unit for at least 20 seconds. Unplug the unit-- I read for 5 seconds, but do so for about 30. It might not play after the first try, but it did eventually. I'm searching right now for a more advanced re-set-- try to get it back to real factory-- right out of the box. Mine won't format for VR mode, let alone the playing problems I have. Hope this helps.
