Question about Toshiba Satellite C655-S5068 Notebook
Toshiba satellite c655 hinge replace - Toshiba Satellite C655-S5068 Notebook
sarahling
    New Friend:
    Problem Solver:
  • 16 Answers
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Posted on May 22, 2013
5 Related Answers
Anonymous
SOURCE: Replacement of Hinges for screen
I have developed a TOSHIBA BRAKE HINGE revision set. It is applicable for Toshiba hinge partnumbers:
P000392930/40
P000377630/40
P000379650/60
P000392250/60
P000394150/60
P000380770/80
P000347860/50
P000349070/60
P000353180/90
P000368300/10
P000378510
See www.impactcomputers.com for models
You need to disassemble your notebook yourself.
See www.irisvista.com
For detailed information mail me: [email protected]
Posted on Apr 07, 2008
Pyrhyc
Ryan Rogers
  • 2028 Answers
SOURCE: Broken Toshiba Satellite R10 hinge
Don't try to have it welded, it won't ever be right again! Your best bet on a hinge is Ebay or a computer shop in the area that sells used laptops. Don't let them sell you one if they don't have one in stock,chances are they are going to get it off Ebay and mark it up 40% just for you. This link should provide the info you need for disassembling your machine.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-R10-R15/open-computer-case-1.htm
Posted on Jun 20, 2008
RescueTechLA
RescueTechLA
  • 2653 Answers
SOURCE: loose screen hinges
You can't. They're worn out and the way they're manufactured doesn't allow for a easy tightening unfortunately. I would pick up a new / used pair from ebay and then just swap them out.
Posted on Feb 20, 2009
Anonymous
  • 92 Answers
SOURCE: have PS245E-06VMY-4C Toshiba satellite laptop but
Im sure you can get them but be very carful because thats where the leads join to the screen to give you pictur. To be honest I would bring it to a repair center and that if there is a problem you have come back...
Posted on Nov 17, 2009
Testimonial: "Its all a matter of if its do-able at a cheap enough cost or not to DIY without mucking things up. Quoted £20 to take the case off just to see. Thanks"
Davethesnake
Davethesnake
  • 689 Answers
SOURCE: I have a toshiba satellite
click hide again or left click
Posted on Sep 05, 2010
I have a Toshiba laptop model# C655-S5501 with a bad keyboard (Gator Aid!). I can't find an exact model # match through Amazon. Will the "Eathtek NEW Keyboard For TOSHIBA SATELLITE C655-S5128 C655
Check eBay. I've been working on computers for years and order ALL of my replacement keyboards through eBay. I just found 9 of them after entering your model number; about $16 with free shipping. Sarawill82 hit the nail on the head for the replacement; you tube is your friend if you're doing it yourself. If it doesn't have your exact laptop, look at other videos. It will give you an idea what you need to look for to replace the keyboard.
It beats paying a computer store a $45+ bench fee, and it will only take you about 15 minutes as a novice.
Don't try to clean it; you could cause more extensive damage than just replacing the keyboard.
Jan 16, 2015 | Toshiba Replacement Keyboard
I have a toshiba satellite C655
some laptops will run with out battery and at some point replace it.
Jun 03, 2014 | Toshiba Satellite C655-S5082 Laptop
Need to replace dvd player in Toshiba Satellite C655
http://www.youtube.com/watch?v=ChrYyWjaEMY Toshiba Satellite C650 L675 DVD Replacement Guide Installation -- L670 C655. Install Fix Replace CD DVD/RW Optical Drive Burner. This guide is useful for these laptop models: TS-L633 - 142, V000210060, C655D, C650D, L675D, L670D
Jan 30, 2013 | Toshiba Satellite A135 Notebook
Power port not working on toshiba c655
You had better replace your laptop charger. Even if you go to repair it, it will cost you the same price of getting a new charger. So it is wise to purchase a new one. Here are two for your reference:
$9.99 for Replacement Toshiba Satellite C655 AC Adapter 65Watt 19V 3.42A
$12.90 for Replacement Toshiba Satellite C655 AC Adapter 75Watt 19V 3.95A
Nov 03, 2012 | Computers & Internet
Toshiba c655
things a pos are you entering it in a show ?
Sep 10, 2012 | Toshiba Satellite C655-S5068 Notebook
Toshiba c655 xp driver
Toshiba lists exactly 170 different C655 Satellite laptop models.
Find your exact Satellite C655 model number then check Toshiba downloads and support at:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Dec 16, 2011 | Toshiba Satellite Computers & Internet
Do toshiba satellites c655 have a built in mic?
The Toshiba Satellite C655 does not have a built in microphone, but it does have a mono microphone jack.
The following website has microphones that are compatible with the microphone jack. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007675%20600011221&IsNodeId=1&name=3.5mm
You may verify at Toshiba's C655 website. It says "No Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite/C650/C655-S5049
Compared with the L670. It says "Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite-pro/L670/L670-EZ1710
I hope this answers your question.
Sincerely, Nathan Hicks
Mar 01, 2011 | Toshiba (P000257700) Microphone
Do my laptop have a mic toshiba satellite c655
There are different models of Toshiba Satellite C655 (about 9 models) and some have webcam and microphone built into LCD bezel (like Satellite C655-S5052 or Satellite C655-S5113) and some don't (like Satellite C655-S5068 and Satellite C655-S5049).
Feb 16, 2011 | Toshiba (P000257700) Microphone
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite C655-S5068 Notebook Logo
2,514 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
