Brother home sewing machines, not part of the Brother Group. C & A Supply Co. Ltd. Unit 5 Williams Court Little Mead, Cranleigh Surrey GU6 8NE GB Tel: +44 ...
Hi Merida
Have you tried adjusting the screen contrast, the following image is from the manual (you may have to press ctrl+ on your keyboard to make the image larger):
first check the outlet to see if it works next check to make sure the power cord is plugged into the machine correctly. if you've done the above things, & you push the switch to turn the machine on & it still won't come on, then the machine needs to be checked.
try changing the needle rethread the machine top & bobbin make sure the bobbin is wound correctly & inserted correctly into the bobbin case if these suggestions don't help then you might think about having the machine checked at a sewing machine shop
try changing the needle also rethread the machine clean under the needle plate & in the bobbin area for loose threads or lint if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
When your Brother PC 7500 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the Brother PC 7500 LCD screen, or buy a new machine.Brother no longer stock this item direct, but there is an affordable replacement available. Check this Link
