Question about Kenwood CT 401 Hi-Fi Stereo Dual Cassette Deck Single Dual Cassette Deck
Sound works only using the audio in rca jacks but won't work with radio, tape, or aux, am I missing something?
5 Related Answers
Anonymous
  • 631 Answers
SOURCE: can't get my amp to turn on
You need to confirm that you have sufficient B+ and remote turn-on voltage.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 07, 2008
Anonymous
SOURCE: AUX input won't work
The red and white RCA terminals on the back of the unit are generally outputs for amplifiers. To use AUX the unit will need to have a 3.5mm jack in the front or rear. If not than the unit does not have AUX input capabilities.
Posted on Feb 20, 2009
Anonymous
  • 63 Answers
SOURCE: I lost Audio output Device
turntable needs high sensitivity preamp. the output level is so low that it has to be amplified more. usual inputs of turntable are phono input. needs a high sensitive input to handle.hope this help.
Posted on Apr 05, 2009
Anonymous
  • 132 Answers
SOURCE: I just put my old
take the blue/white wire coming from the radio and tie that in with your solid blue wire coming from the radio and which is connected to whichever wire in the car. So in total you'll have 3 wires at a connector.
Posted on Sep 25, 2011
Albert wells
SOURCE: RCA jacks on kenwood head unit do not function
Just run your amp on the front RCA and tune it on your amp they can blow which sounds like whats happend hope this helps
Posted on Mar 18, 2013
How to hook up my pc's audio to rca rs3531 to
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level (AUX in your case) input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
http://www.retrevo.com/support/RCA-RS3531-manual/id/19240dj989/t/2/
Jul 26, 2011 | RCA port Turntable with CD&Digital Radio...
I have a JBL MR 15 does this radio have a place in the back to plug in an ipod adapter. I think it is an Aux input RCA Jack The radio is on my boat and not near for me to look at it.
if it has aux input rca's, then go to an electronics or car audio shop and buy a "stereo rca to 3.5mm headphone jack adapter cable" This will then plug into the headphone jack on the ipod.
Jun 13, 2011 | JBL MR-15 CD Player
Sony DHC-MD333- Is there AUX to attach to laptop??
the lines in for the tape deck would likely work. or look for any other inputs on the unit.
you will need a mini (headphone) jack to stereo RCA cable's. your local radio shack sells them. walmart also carries them.
you can also use an headphone extension cable and coupler then connect the coupler to the headphone to RCA cable.
picture of it here
http://budgetgamer.files.wordpress.com/2008/08/audio1-rca-to-headphone.jpg
Aug 06, 2009 | Sony DHC-MD333 Shelf System
I have a cable box...(hddvr) and a TV cable set it up on video 2 now i bought a insigna home sound, how do i hook it up the user guide only shows me how to hook it directly to TV and its not working, so...
First, if you have the jacks in back of your TV for audio out, you may have to set the audio on the TV for external audio. Go to menu and then click on audio or audio options, and see if there is a mode for external or aux audio out.If that does not work, then use cables with the RCA ends and hook up from cable box to audio in or aux in of your surround sound system. Look at the back of the cable box for audio out or aux audio output and connect these two jacks to the audio in or aux input of your surround system.
If the cable box does not have extra audio out, you can take Y connectors and branch off the two jacks that are going to your TV. Radio Shack has these Y connectors. They allow two cables to be connected to one jack.
Hope this helps, if so Please rate, and Good Luck!
Aug 02, 2009 | Audio Players & Recorders
How do I play music from my lap top on this sound system?
your laptop has an audio output jack that is 1/8 inch sterio .. your sound system likely has RCA input jacks .. you can get a cable from radio shack that has a 1/8 inch (3.5mm) sterio plug on one end and two RCA plugs on the other ..
plug the 1/8 inch jack into your computers audio output (headphone jack) .. the RCA plugs will connect to the AUX (analog) input on your sound system .. select AUX on your sterio system to select the computers input .. now you should have great sound from your computer . the computer likely provides only sterio information so the multi (7) channel feature of your sound system will have to fake it ..
Jul 24, 2009 | Pioneer SX-315
Unsure how to connect up external connections need to see illustration for these connections as i do not have any info'
tape decks has a line out and line in RCA jack at the rear this is for the amplifier connection. line out should be connect to amplifier line in jack. Tape deck has also RCA jack input for Radio or Tuner, Phono, VCR, or CD, and Aux. You can input the audio out R&L to the selected input above.
Jun 21, 2009 | Audio Players & Recorders
Feb 17, 2009 | Kenwood KDC-135 CD Player
I have an old Sansui au999 amp
you can go about this many ways.depending on what you have to work with.are you useing a satilite or cable box?if so assuming they have audio/video out just send the audio to the amp and the video cable to the tv.u could use the aux or the tape in.just put the dvd in the other input aux or tape in.dont matter which.if you dont have a cable box your tv must have some kind of audio out to run to the amp.it can be a rca out or simply a headphone jack.you will need a headphone jack too rca plug cable if you have a headphonejack on your tv.hope i could be of help.
Jan 05, 2009 | Sansui Audio Players & Recorders
Aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Aug 13, 2008 | Kenwood KDC-MP435U CD Player
SIRIUS RADIO
that unit has aux inputs in the back they are rca level inputs.. your "stratus" has an audio output that is a 3.5 mm jack or standard headphone jack, with the appropriate patch cord, you can connect the two devices giving you the best possible sound quality. you would use the aux source on the head unit to listen to sirius. this feature may need to be turned on in the menu.
Feb 10, 2008 | Panasonic CQ-C8303U CD Player
Top Kenwood Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
Kardoc
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
