Question about Crosley CR79 CD Shelf System
Cd player has err
Cd player says 10 err when we insert cd. won't work at all.
Posted by katrinnafrui on
John Cunningham
  • Crosley Master
  • 6,771 Answers
The CD player is defective, if the Crosley has Aux audio input jack, you can buy a cheap CD player which would be a far cheaper alternative.
Posted on Mar 11, 2012
Vw beetle cd player wont read
I purchased a CD cleaner, ejected the magazine, inserted the disk after removing all disks in magazine, ran the cleaner through the cleaning process, then reinserted the disks and now both professionally made and homemade disks are working again
May 08, 2013 | Car Audio & Video
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
Delco factory Radio/CD player,it gives an err msg.and ejects CD
The laser in the cd player may be dirty or has gone bad and can no longer read the disc.
Apr 17, 2010 | 1998 Chevrolet S-10 Pickup
Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Nov 18, 2008 | 1997 Saturn SL
Crosley CR79 CD Shelf System Logo
290 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
