I've checked the thermal fuse and it's ok. I hear the timer while I hold in the start button. I discovered the belt is broken, but nothing runs. Could the motor be bad?
SOURCE: I have an older model Kenmore electric dryer 80
I hope this information will help U
http://repair2000.com/norun.html
was this helpful?
Several different problems could prevent your dryer from running. Make sure that the door is firmly closed and hold down the start button for a couple of seconds to start the dryer. If you hear a click from the control board then the door switch and the control board are likely okay. You could have a blown thermal fuse or a broken belt in the dryer. To check these components,unplug the dryer and remove the bottom front service panel as shown in the first image below. With this panel removed, you can tell whether the drive belt is broken. If the drive belt is okay, I recommend checking the thermal fuse. This fuse is located on the blower housing as shown in the second image below. It will have light blue wires attached. To test the fuse, remove one wire and measure the resistance across the leads of the fuse with a volt/ohm meter. You should measure near zero ohms of resistance (continuity). If you measure infinite resistance, then the fuse is blown and will need to be replaced. You can verify that this is your failure by taping the contacts of the light blue wires together with electrical tape to "bypass" the thermal fuse. Reassemble the dryer and see if the motor runs with this fuse bypassed. If it does, then this verifies that the blown thermal fuse prevented the dryer from running and that this was the only failure. NOTE: Do not continue to run the dryer beyond this brief test with the thermal fuse bypassed. This component must be replaced. It is an important safety feature of the dryer.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3392519.
