I have Office 2010 on Windows 7 pc and at least 3 times per day my Outlook will not open. I have to Force shutdown then reboot and open it in Safe Mode. It drives me crazy. Can this be fixed?
Hi Tami,
You can fix your Outlook problem with the help of Scanpst.exe .
With The help of Scanpst.exe you can repair your pst file just run the program and if everything is ok you can recover your PST File and after taht you can open your Outlook without any problem.
As The .pst file corrution is the problem of your not opening Outlook so after the pst repair ther is no isues .
If you did not repair your .pst file with help of Scanpst.exc program don't worry there so many third party data recovery for Outlook PST you can also try this type of software one of them which is personally used by me is Kernel for PST Repair you can try this software from here
http://www.pstrecoverytool.net/
Hi
You can use Scanpst (Inbox Repair Tool) for recovering from this error. This is a free tool. I would like to refer to a blog that will help you out.
Read now- http://www.how2repairoutlookpst.com/blog/download-scanpst-exe/
It contains complete information on how to download and use it.
Hi Tami,
You can fix this problem easily. You just have to do some changes in Outlook properties. The same topic has discussed at different thread, you can go there by clicking on below link.
cannot start Outlook This message comes up every time try cannot start...
You may experience these problems ,and the most possible reason for this may be corruption of PST files in Outlook. so the best way to fix Outlook issues is to repair corrupt PST file in outlook. Use inbuilt repair tool or if not woks than you may use Outlook PST Repair software it is one of the most efficient and
Yup....!!!
There are times when the Outlook application will not respond and this might be because of some of the hardware or software reasons. But the worse part is that it will make the data in-accessible so there is always a need to resolve the corruption. you can use the inbuilt utility that is scanpst.exe to fix the corruption but in some of the severe cases of corruption this may fails to fix the corruption.
Then you can use the PST Repair Tool to resolve the corruption. This is a powerful utility that will make the recovery of the severely damaged data with an ease. And this is an all in one solution for corruption and damage. Further information about the software can be gathered from : https://www.prbuzz.com/computer-software/102972-pst-repair-tool.html
Hi, http://www.oversizedpst.com/recover-emails-from-oversized-pst-file.html
Sometimes what happens that the Outlook may refuse to open due to the PST file oversized problem. So in order to solve this problem, you need to repair the oversized PST file using Scanpst tool. If it does not work then you can use the third party tool. The below mentioned website contains more detailed information about how to solve oversized PST file problem.
Asunsoft Word Password Recovery is one of the most popular Word Password Recovery tool in the market, which can help you crack a password of Word in whichever versions, 97, 2003, 2007 or 2010. A password made up of less than 3 characters can be recovered within 1 second. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack, so that it can greatly shorten the recovery time if you partially remember your password.
Asunsoft Office Password Recovery is an all-in one MS document password recovery tool which can crack password of Microsoft Word, Microsoft Excel, Microsoft PowerPoint, Microsoft Access, and Microsoft Outlook. It offers a professional set of features wrapped in a very user-friendly form that is easy to master. It offers three powerful attack types: Brute-Force Attack, Brute-force with Mask Attack and Dictionary Attack.
Asunsoft Word Password Remover is a must-have password recovery tool which has the highest speed for you to crack Word password and has 100% recovery rate. The usage is very simple that you just need to click OPEN button to import a locked Word document and click Remove. Seconds later you can open it without password.
Thank you so much Jane. For some reason (and this could be the problem) I did not have the .pst file anywhere on my c drive. This could be from when I had a computer crash some time ago and my back up system saved it to something else (I have no idea what) I use Carbonite. So I went to ScanPST.exe Fix and downloaded the free version and I think it may have fixed it but I am not sure. Time will tell. As I said before - it happends periodically, usually when I really need to get into my email. I will keep you posted Jane. Again, Thank you for taking the time to address this problem.
Hi Tami,
Thanks for reply. You are most welcome in case you want any type of help to get back your emails back. I will completely try my best. Keep posting.
Regards
Jane
