SOURCE: BD-P1590 won't play some discs
It may be a disc incompatibilty. Make sure you have the latest firmware for your unit. Report the problem to samsung to see if you there is a issue or a future fix. Blu-ray players are STILL trying to be finalized and only recently have they gotten smoother. Some players are better at some discs than others. Please take a sec to let me know if this helps.
Testimonial: "I really appreciated your effort to help. Unfortunately, the "Lie To Me" disc isn't blu-ray. I called Samsung, and they say that updated firmware will"
SOURCE: blu ray want connect to the internet
You have to buy a Samsung wireless adapter in order to use a wireless conection..look up your player at www.avsforums.com for any and all questions and answers.
SOURCE: I can't get our Samsung Blu-ray player(Model
I am not an expert a "tinkerer"at best but I do have the 3600 like you and I have no problems connecting. Make sure there aren't any spaces or special characters in you router name. Follow your instruction manual and get the 3600 connected first then try netflix: Menu, setup, network, set your settings and it will tell you available networks, choose yours, enter your security code then do a connection test. If its not connecting at what step are you having a problem?
SOURCE: My Blu-Ray BDP1590 Samsung freezes at the title
Try to reset system at Samsung support. To do this you just take disc out, hold the FF button down on unit until you see "reset" then select language. Turn system off then hold power button for 15 sec. Then restart system.
As far as Netflix you got to got to system, determine if you are using wireless or cable. You have to set this yourself.
You should also update your firmware here at http://www.samsung.com/us/consumer/tv-video/blu-ray/blu-ray-players/BD-P1590/XAA/index.idx?pagetype=prd_detail&returnurl=
You will see a support tab, which has your download on it. I would try the CD based download first.Download the file, unzip it, and burn it onto a CD. Then, with the unit off, and unplugged, plug it in, open the drawer and insert the disk. Close the drawer and see if it will read the new files. If not, then try the same procedure on the USB option.
Thank you!
SOURCE: i have a samsung BD-1590
Follow these steps:
1. Connect your device to the internet
2. Find and start Netflix on your device
3. Netflix will provide the activation code on your device
Access this Netfix website on you PC and click on the menu option "Instantly to your TV"
Enter the code provided by your player into the prompt and it should immediately give you access!
Hope this was helpful!
