Question about Krups Dolce Gusto KP 2100 Espresso Machine
Can not remove capsule and lever stuck
Capsule is stuck in compartment and lever that punch hole in capsule will not go up stuck on the down
Posted by anne murphy on
RoyP
    New Friend:
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Posted on Apr 21, 2012
  • 1 more comment
  • R Minshull Oct 25, 2016
    After wasting my time for 2 hours drilled a small hole in pod problem solved. Working perfectly again.
  • Ricardo Fonseca (Rifosi)
    This procedure solved the problem. Thank you very much!
  • Tommy Teoh
    Tommy Teoh Jun 02, 2020
    Oh yes, it solved mine too with a screw from the bottom, and to release the capsule pressure the moment I removed the screw.
adam340
    New Friend:
I too had to put a small pin prick in the capsule underneath to release the pressure.
The cause we me putting a capsule in and putting the lever down and turning it on without enough water in the tank. Walked away and came back an hour later. The pressure had built up and the lever was clamped down.
Posted on Jan 28, 2013
Ricardo Andrade
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Help, mine Krups capsule the lever don´t close with or without capsule. i don´t know whats the problem. any help to resolve this problem. thanks
Posted on Mar 14, 2017
Nick Day
    New Friend:
Turned ours upside down and fiddled with handle without using force. Handle eventually came up as normal. Problem was a third-party plastic pod which had squished rather than be perforated.
Posted on Oct 16, 2016
Gerald buhagiar
    Habit-Forming:
    New Friend:
  • 158 Answers
Is you melody auto if yes you may have to reset the gears .if your melody is manual and capsule is stuck you have to make a hole in the capsule from under the capsule holder to remove the water which had not come out it is only then that handle is save to open .you if the capsule is file with water it be comes a little bigger and it get stuck sow you have to release that presure
Posted on Feb 25, 2016
Simon Woodward
    New Friend:
This can occur if you have left a capsule in the machine an the pod becomes 'bonded' to the needle in the foil lid. I found that by inserting a narrow pocket knife blade up into the capsule outlet and twisting it, I could break that bond and stop the capsule from rising out of its cradle when l lifted the lever.
Posted on Aug 02, 2014
How do i manually retract - Exterior door stuck closed - removed knobs (levers)
PUT A SCREW DRIVER IN THE HOLE AND TURN IT
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/joe_0ca6379e2eceb740
May 25, 2014 | Kwikset Lido Polished Brass Entry Lever...
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Nespresso essenza lever stuck
My Nespresso lever won't push back and it won't produce any coffee from capsule that is stuck in machine.
Jun 13, 2012 | Nespresso Essenza C100 Espresso...
When i put in the nespresso cup in the Citiz and close it nothing happens. Ussually it should make holes in the cup so the coffee can come out. But there are no holes when i open it again. So i can not...
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Jun 08, 2011 | Krups Coffee Makers & Espresso Machines
My Nespresso Magimix Citiz does not pierce the capsules every time. I use only Nespresso capsules. I have tried to pass them through a second or third time when this happens but I have thrown too many...
Mar 02, 2011 | Nespresso C100/T-US-AERO Espresso Machine
My machine leaks water into the capsul box and doesn't punch holes or not enough in the capsule when pushing it in. Coffee is very weak because not enough coffee is reached in the capsule and water is...
Mar 01, 2011 | Nespresso Citiz D110
The capsule lock system does not make holes in the capsule
Oct 09, 2009 | Nespresso Le Cube
Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Sep 18, 2009 | Nespresso C100B Essenza Single-Serve...
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Krups Dolce Gusto KP 2100 Espresso Machine Logo
25,793 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
