Becuase this model IS a DVD player, the remote controller will not allow another of the same type. This remote can be programmed to control a TV, Cable Box, DBS tuner, and VCR. It will not control VHS or another DVD player
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Try any older Sony DVD player code like the DVP-CX995. Sony has had the same basic codes for years. You will be missing blue, green, yellow, and red buttons since they are not available on the remote.
For a true one button solution check out the MX-900.
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Player can be made to work without remote. But it is a pain.
You need to press pause then play in the right combination.and you can get both DVDs and Blu Ray disks to work. I bought a store floor model that did not have a remote. I went through the same problem when I would lose the remote for the HD-DVD player. My four year old daughter knows this trick pause pause play for DVDs and pause play pause play for blu
