Question about Uniden DECT 6.0 Cordless Phone ID
How can i bypass a forgotton pin number to set up voice mail on my uniden dect 6.0 corless phone
Posted by Alain Fortier on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only suggest that you select it from the list beginning here to download the manual. The manual will tell you how to change the PIN and set up the voicemail system.
Posted on Mar 10, 2012
5 Related Answers
One Wire
Dean Pitts
  • 126 Answers
SOURCE: checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Posted on Jan 26, 2008
Anonymous
SOURCE: Will Uniden 2085 DECT phone work in india
Caller ID standards are different in India,so caller id won't display ; need to buy a converter which converts from DTMF to BellFSK standard
Posted on Aug 24, 2009
Anonymous
SOURCE: No dial tone on Uniden Dect 6.0 land line and portable phone
We've had the same problem with our new Uniden phone. Sounds like someone's on the other line - no dial tone and answering machine doesn't work. The telephone line works though because we plugged our old phone in and it works fine. Any solutions anyone?
Posted on Feb 05, 2011
Anonymous
SOURCE: uniden dect 6.0 1560-2 phone - caller id shows my own number
caller id not working
Posted on Feb 21, 2011
pgh_pa_guy
  • 2992 Answers
SOURCE: Uniden Dect1560 - For incoming
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Posted on Jul 24, 2011
Testimonial: "Thank you. Great answer."
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I set up voice mail for my uniden 6.0 without answering system
If you do not have an answering system (answering machine) on the phone, you need to purchase a answering machine or contact your telephone service provider to get Voice Mail service from them. (Most charge $3-5 per month for voice mail.) The provider will tell you what number to call to set up a voice mail message and access messages.
I hope this helps.
(for most Uniden systems with the answering system, you need to turn it on and then access the system from the handset to set the out-going message and length of incoming messages allowed.)
Mar 18, 2013 | Uniden DECT 6.0 Cordless Telephone...
How do I retrieve voice mail messages from my uniden dect 6.0?
LED on the handset flashes and appears in the handset display whenever you have messages waiting in your
Feb 13, 2013 | Uniden DECT 6.0 Cordless Telephone...
Uniden dect 6
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only suggest that you select it from the list beginning here to download a copy of the manual.
Feb 20, 2012 | Uniden DECT 6.0 Cordless Phone ID
Cannot find/remember the password to check the voice mail in the Uniden Dect 6.0. Any ideas?
You didn't specify the model of your Uniden DECT 6.0 system so I can't give you a definite answer, but on many models you press the Menu/OK button to access the main menu, scroll to the "AM Operation" submenu, then select "Remote PIN" to change it.
Select the model from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to get the manual for your system.
Jun 17, 2011 | Uniden DECT 6.0 Cordless Phone ID
Lost manual for DECT 6.0 phone. Hopping to download manual. Don't know how to get voice mail from unit.
You can find a users manual at: http://www.uniden.com/index/manuals_results.cfm?cat=1
You will have to know what model it is, usually you can find that out by looking at the bottom of the base, or on the underside of the battery cover, or under the battery.
As for getting the voice mail, if you use your providers voice mail service, usually you have to dial something like *99 or *00. You would have to contact your phone provider and find out what the number is to reach your voice mail.
Mar 08, 2010 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 6.0 Cordless Phone ID Logo
281 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
