Aurora Electronics AS1018CD Shredder Logo
Question about Aurora Electronics AS1018CD Shredder
Shredder wont shred
When u turn on light will only stay red and will not shred. Nothing stuck in blades. No place to open and check for other issues
Posted by todd jurasek on
mike kirschbaum
    Genius:
  • 1,198 Answers
My boss has a shredder that will not run unless the bin is exactly centered in the bottom of the unit. There is a safety switch inside there, and a magnet to activate it. Make sure nothing is interfering with the bin or the shredder fitting together.
On other units, there is a slot that must match up with the shredder. It will only work one way. See of the shredder will turn around and put it on the bin the other way.
Posted on Mar 10, 2012
We have a Fellowes Powershred C0320C shredder which will does not take the material to be shredded except on one end and does not pull it in and shred it.
Try to use the reverse action of the shredder. This runs the shredder blades in reverse and sometime CLEARS the left over shredded material that can cause a malfunction. Careful...watch your fingers as the blades are sharp and they can injure you. Never place your hands or garments near the open blades when it is plugged in.
Check also that the small switch is free and clear of derbies. When the cutting gears are in place on the container box, the small actuator switch is free to turn on or off until the shredding box is full. Once the box is full of shredded material the switch will turn off (a safety provision) and you must empty the container before it will operated again.
2answers
Our shredder will not anymore shred the red light will signal
Blades probably Jammed
Safety First
Power Disconnected
Open up and free the mechanism
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
I have a Royal VF 1000mx shredder. I start shredding and all of a sudden shredder stops and red lights appear. I reverse shredder to see if it clears the problem but it happens again. Would appreciate...
Try removing the shredder head from the bin and look for scrap of paper jamming up the blades.
Run it open, laid on its back.
Check visually for bent cutting blades.
Are the two shafts (with mounted blades) parallel?
A shaft may have come loose inside head assembly.
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
2answers
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
Does not shred red light on
Try soaking the cutter blades with hot soapy water overnight thru the feed slot
8helpful
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Will not shred
I work with Fellowes machines so I am not familiar with this brand but it sounds like an issue similar to our safety interlock which tells the machine the bin is in place and ready for shredding you may have to contact manufacturer about this unless someone else here knows if your unit has a switch similar to this.
Top Aurora Electronics Office Equipment & Supplies Experts
Marvin
Marvin
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
