SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
SOURCE: water leak
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
SOURCE: frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
SOURCE: freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
SOURCE: flashing freezer temp on Samsung SR S22
how to remove cover from twin cooler samsung sr-s20-s22
when you turn it on, can you hear the compressor running?
Yes,I can hear it buzzing......this happened before,and repair guy just used a hairdryer to defrost the water pipe in the fridge section,after 48 hours it was just the same,then another chap came and said the gas has gone and he replaced it....9 months on,the same problem has come back. I defrosted the whole unit for 4 days,switched it back on.....fridge ok,but freezer is not working still?
the freezer is trying to work,but has managed only -4.....the reading is altering all the time...,but the liquid sachets I have left in there never manage to freeze.
