SOURCE: Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
SOURCE: Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
