SOURCE: Iam using nokia 5310 Xpress music phone.camera on stand by
Once the camera of the Nokia 5310 is in stand by mode, meaning that the camera is not functioning correctly. Unfortunately, there's no settings that we can change to fix this.
You need to bring the phone to the Nokia Care Center and have them upgrade the firmware of the phone and that should resolve the issue.
Thank you!
SOURCE: lost security code to nokia 5310 xpress music
4047645535 try this may be work it is master code
SOURCE: nokia 5800 music xpress display problem
Sounds like the connection from the phone and ur touch screen is loose. Would suggest getting a technician to fix it. There are online resources that also show you how to do it.
SOURCE: Message icon keep flashing
change ur message memory from phone memory to card memory, its blinking because your message memory is full.
Testimonial: "Thank you very much.You helped a lot."
SOURCE: I have nokia 5310 Music xpress I want to restore
Hello :
Switch-off
your phone.
1. Press and hold 3 keys; Green
dial key, * Star key, no. 3 key on keypad and then press the power
on/off to switch on the phone.
Remember, do not let
go the 3
press and hold keys until you see a formatting word screen show!
2.
After a few minutes when the Full phone formatting completed, your
phone will back to original system and factory setting.
[by the way that will restore factory settings of your device ] .
back
up all of your important data before you do it ]
good luck
Steps to Restore Factory Settings
This restores the original settings of the device.
