Boating Logo
Posted on Mar 08, 2012
Great white trolling motor,bow mount,24 volt, 82lb thrust / big problems! Burned up Marinco plug,replaced plug,recetacle,fuses on. batteries, tech says motor runs fine on bench,but not on boat. Getting 24 volts at receptacle,but volts drop when motor is plugged in! Help! Thanks,sam vitter
Loye
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 10, 2012
Loye
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
347
Points
The heat is developed from to much resistance from batteries to TM, check for loose/corroded connections at batteries, including the jumperwire, also check the size of wire from battery to plug, should be at least 8 gauge if not 6 gauge depending on the length of run. If corrosion has built up inside the wires this will also cause high resistance causing excessive heat build up. I would prolly just replace boat wiring to make sure none of the above problems are present. Use tinned copper marine grade wire that is multi stranded.
2 Related Answers
Anonymous
  • Posted on May 22, 2009
SOURCE: when wiring a trolling motor to a battery di I
THE POSSITIVE ONLY IS CORRECT AND OR SUFFICIENT , AS CLOSE TO THE BATTERY AS POSSIBLE
Anonymous
  • 69 Answers
  • Posted on Mar 27, 2010
SOURCE: Installing a Terrova Trolling Motor Bow mount to a
Personaly I would drill through and use a nylon backing sealed with siicaflex. Your boat your call.
2answers
Great white wont turn motor runs but wont turn
Do you mean you can hear the motor turn but the propellor doesn't turn?
Then check the break-pin of the propellor. It's a security device that will break when the propellor hits an object in the water...
The turn feature on my remote trolling motor will not work
Maybe the pin is sheated on the prop...or something is caught in it..
check the prop.
4helpful
2answers
I have a 74LBS thrust trolling motor that hasn't never in my opion worked right, I don't think its wired right to get the proper 24 volts, However I have took it loose and hooked it directly to 2 marine...
Here is a picture of the wire connection for 24 volt. Compare to yours is it correct? If it is, I wish you listed make and model I could of sent you the right picture diagram of you motor. Use this picture as a starting point. Test the wires through the motor testing for 24 volts. Again if I knew make and model I could show you exactly were. Last if voltage is correct all the way through. The motor is the last thing to tear down. If the brushes or armeture is damaged in anyway, or manufactured wrong, it would lead to power loss.
What size batteries needed for minn kota 24 volt 74lb thrust
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
3helpful
2answers
Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
1helpful
2answers
Proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
