You need to get into the menu, there is an invert image option as the projector can be mounted upright or upside down depending on the mounting of the projector
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
1. Press the KEYSTONE button on the remote control.
2. Go down to Manual with the \/ or /\ button, then press > to select it.
3. Select V:INVERT, or H&V:INVERT, to flip the image.
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
normally there is a micro switch fixed at the awivl head of the lcd
panel. when the lcd is rotated to 180 the switch gets engaged thus
turns the image upside down. iF IT IS PERMANENTLY UPSIDE DOWN yhen most probably the switch has worn out.and its not resetting. You could try a few gentle taps to see if it releases the micro switch
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
