Not staying hot long enough
SOURCE: How do you turn off
there should be a manual lever there that says on/off. or you should be able to turn the dial until you hear a click
SOURCE: i need to get some
4000 series Paragon timer uses X2772 tripper
To check your model:
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Midnight electric sells X2772 tripper
http://midlightelectric.com/firex/acatalog/FIREXPARAGONROBERTSHAW_X2772.html
That being said,
According to e-mail I got from Paragon last month, Paragon is no longer making timers or timer parts. Except for defrost timers. 4000 series is not a defrost timer.
This explains why some sellers of these trippers are asking $50 or more for $3 pair of trippers.
To change your timer to Intermatic.
Refer to Intermatic cross reference:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
SOURCE: My hot water heater timer
Paragon is no longer making timers and parts, except defrost timers.
I've seen X2772 trippers selling for $50-60
Can I suggest a replacement water heater timer:
Link below shows variety of water heater timers (including Paragon products, Intermatic, Tork, GE, Sylvania, Woods). Page has wiring diagrams and manuals.
http://waterheatertimer.org/Boxtype.html
Look at label on side of tank to see if heater is 120V or 240V
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: need trippers for older unknown model number amf
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
