Question about Samson C01U - USB Studio Condenser Microphone Consumer Microphone
Co1u Static I have static feedback on my co1u and now my friends won't even talk to me on skype.
5 Related Answers
Anonymous
SOURCE: Problem with Samson CO1U
Of course it's going to be quiet if you don't turn up the volume.
You don't need SoftPre. Just increase the gain of the mic using the normal gain control. Go to Control Panel --> Sounds and Audio Devices --> Audio tab. Select Samson C01U as the Sound recording device and then press the Volume button. Slide the slider more near the top.
Posted on Mar 28, 2008
Anonymous
SOURCE: Cannot hear sound from mic
i can't install logitech desk mike model ak 5370 in vista
Posted on Jan 04, 2009
ABRsvcs
  • 4234 Answers
SOURCE: SAMSON CO1U recordings sound like they're underwater on my MAC
The behavior you describe suggests that the mic is not getting power. Since it is a condenser mic, it requires what is usually called "phantom power". This should be provided thru the USB port. Check to be sure that the USB port is supplying that power. Check with another port for example. If that fails, you may have a defective mic.
Keep us posted.
Dan
Posted on Feb 10, 2009
Michial Gueffroy
  • 1140 Answers
SOURCE: Cant get any sound from mic!!!!
Go into Play control on your computer. Click on options then properties. Look at your settings for playback and recording. Check play control and your source eg. microphone. To reach this double click on the speaker icon in your toolbar or you can find it under sounds and devices in your control panel.
Posted on May 30, 2009
Anonymous
SOURCE: static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Posted on Aug 16, 2009
My mic doesn't work
sounds like a bad mic or bad wiring. Either way I would replace it.
Apr 17, 2014 | Imicro Sp-im942 Multimedia Stereo Headset
Im gettin only one side when i record a vocal wit mixcraft 3
Make sure your recording onto a Mono track in your software, don't choose stereo when creating the track.
Feb 20, 2010 | Samson C01U USB Condenser Microphone...
May 23, 2009 | Samson C01U Consumer Microphone
Keep us posted.
Dan
Feb 10, 2009 | Samson C01U - USB Studio Condenser...
Static with playback on samson-gtrack with windows xp
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Cannot hear sound from mic on Samson CO1U.
Jan 03, 2009 | Samson C01U Consumer Microphone
Anytime I turn on Webcam and the mic on this unit the receiver is hearing a lot of noise coming from my end
Normal 0 First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
May 24, 2008 | Microsoft LifeCam NX-6000 Webcam
SAMSON CO1U USB MIC FAILURE
Your first issue is vista... it just sucks. I would have to be there to figure this one out but im going to state the obvious, does it have an installation cd you didnt use? does it have online drivers you can find? Try looking around in your control panel and messing around with some of the options, good luck.
May 01, 2008 | Computers & Internet
Samson C01U - USB Studio Condenser Microphone Consumer Microphone Logo
56 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
ray gallant
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
