Question about JVC AM FM CD DET FACE CAR STEREO
KD-SX870 car stereo, when cd is inserted, after 10 sec. it says
I get "eject disc" after inserting a disc in CD Player. I've went by the manual suggestions and removed face plate and pushed reset. It still says eject disc. any help ?
Posted by TLowe on
josetejas
    President:
  • JVC Expert
  • 300 Answers
The CD mechanism is broken. Need repair.
Posted on Mar 10, 2012
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: JVC KD -S680 needs help
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Posted on Sep 25, 2006
Anonymous
  • 4 Answers
SOURCE: when i insert a cd to my jvc car stereo it does
2 common faults, either the disc is not loading fully
into the cd mechanism or the laser is dirty or failing.
To resolve the fault the unit will have to be removed
from car and inspected on bench. Obviously there
are can be alot of other reasons why the cd has failed,
you will require a reasonable background in electronics to
trace and repair.
Goodluck
Posted on Mar 19, 2009
Anonymous
  • 174 Answers
SOURCE: I need to buy the face plate only because the original got stolen
Call 0121 5206666 or google A.E.L they are based by us, and as a former engineer repairing the stereo's i can vouch for their quality and speed.
Posted on May 24, 2009
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: cleaning cd player on my JVC KD-S570
Laser Lens Cleaner. Looks like a regular CD, but it uses soft brushes that clean the lens. The better quality ones use fluid as well. You can find them in just about every retail store that sells CD's/DVD's or electronics. Chances are your transport has a problem or the lens is out of align. There is no fix for this, they just put a new transport in the unit it's less expensive. Hope this helps
Posted on Jun 10, 2009
kenw392
kenw392
  • 2226 Answers
SOURCE: replacement face plate
try pacparts.com
Posted on Sep 14, 2009
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
I have a cd stuck in the radio & it won't eject it (states no cd), makes a clcking sound. how to fix it?
Usually there is a hole in close to the cd slot, where a pin can be inserted in order to push out a cd manually or a similar manual override.
Which CD player/ radio are you using?
Jul 01, 2017 | 2004 Chevrolet Avalanche
What does DCP stand for?
[Detachable Control Panel].. Which is your face plate.. I take your having trouble , remove all disk USB mpe attacehed remove face plate you will see a little hole you will need like a paper clip to push the button for about 2 seconds to reset the unit. after resettting attach face plate and try unit.
Feb 25, 2014 | Clarion CX609 Car CD/ MP3 Player
Removing a stuck cd from a player
There are two causes that spring to mind - CD's can warp with heat if left in at high temperatures or the player itself may be worn out. Anyhow to remove I would try:
First: Keep the eject button pressed in as you turn on the player this is like a manual override
Second: If the face is detachable remove the face and see if there is a small hole that you can insert the end of a paper clip in some players have a manual over-ride. Or there may be an over-ride button.
Thirdly: With power off - Use friction - try (gently) inserting a disk (one you don't care if you damage) like an old CD-R over the top of the jammed disk say 1/3 to half way and pull see if the extra pressure can manually remove the disk. You could try other items that are thin and without sharp edges to avoid potential damage.
My last suggestion: Stereo surgery - remove the head unit and cover. Depending on the design you may be able to coax the disk encouraging it out gently with say a screwdriver through the housing brackets.
Jan 08, 2013 | Cars & Trucks
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
Aiwa CDC-x204 stuck in demo mode
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 24, 2012 | Car Audio & Video
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
How do you get the "LOUD" screen to come on the
Some of JVC higher end models have a feature called BBE. The BBE button has replaced the loud feature on these models, so there is no Loud button on them. Some of these display panels still might show the Loud indication due to the display boards used.
I suggest check ypour User Guide for additional details. Good luck.
Oct 14, 2011 | JVC KD-SX870 CD Player
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
JVC AM FM CD DET FACE CAR STEREO Logo
141 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
