SOURCE: Black screen, yet able to review past pictures
There is a recall on these cameras. Canon will fix for free and pay for all shipping costs. They have been very helpful.
Service Notice: CCD Image Sensor Advisory (Updated 10/31/2006)
PowerShot S1 IS
This Service Notice will update Canon U.S.A., Inc.'s previous CCD Image Sensor Advisory, dated October 6, 2005.
It has come to our attention that the vendor-supplied CCD image sensor used in certain Canon digital cameras and digital video camcorders may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all. While reports of this malfunction have been rare in the United States, we have determined that it may occur if the product is exposed to hot and humid environments.
Notice of Additional Affected Products:
As a result of our continuing investigation of this malfunction, we have determined that the 11 models listed below, in addition to the 16 models listed in our Service Notice concerning this malfunction, dated October 6, 2005, may be affected.
Affected products:
- Camcorders: ZR60, ZR65 MC, ZR70 MC, ZR80, ZR85, ZR90, ELURA 40 MC, ELURA 50
- Digital Cameras A60, A70, A75, A300, A310, S230, SD100, SD110, A40(*), A80(*), A85(*), A95(*), S1 IS(*), S60(*), S200(*), S330(*), S400(*), S410(*), S500(*)
*Models added as of Oct.31, 2006
Malfunction:
It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image.
Canon's Response:
Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to [email protected]
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
SOURCE: when i turn on my canon powershot sd750 the screen
Hello
The problem is that the lens has become stuck in the barrel
after dropping it. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
