Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Need instruction manual for Euro-Pro Shark Steam Mop model # s3505w
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Shark model by clicking the link below.
Shark S3505W Owner Manual
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Nov 05, 2017
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
I just had the same problem and I went ahead and opened the steam mop up with a screw driver and there was the grey pump that pumps steam to the mop pads was clogged with hard water build up and unclogged the pump and it worked right away...
Posted on Sep 26, 2009
SOURCE: euro-pro Shark steam mop has a broken handle.
I have broken 4 shark handles, have repaired them its a pain. remove the screws on the handle end of the head pop out the broken handle part, drill a 3/16 hole into the part tap 1/4 inch threads use a countersunk head 1/4 inch bolt screw it together put epoxy on the inside to lock threads reassemble. its a pain. two small keepers lock the swivel together pry out with a screwdriver carefully dont loose them. I broke one shark handle when it was brand new. this repair works good if you like alot of fooling around
Posted on Mar 31, 2010
SOURCE: My steam mop does not make steam.
how do you get a shark steam cleaner unclogged?
Posted on Jul 14, 2010
SOURCE: NEED AN INSTRUCTION MANUAL
Yes, you can use it on carpets...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
Here
may not be getting steam to the head...
Euro-Pro
Here
Manuals
that you need.
heatman101
-=-=[p[][]
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
heatman101
heatman101
