Http://laundry.manualsonline.com/manuals/mfg/samsung/samsung_washer_product_list.html
There is a free manual for downloading -good luck
kolbrun
SOURCE: Samsung Washing machine fault
possibly a blockage at the end of the thin pressure hose where it fits onto drum ie;scale or soap powder. Also clean the chamber/hose it fits onto
SOURCE: samsung b1245s washing machine
Error code is actually 5e and is to do with your drainage being blocked. Check the flap in the lower right of the machine. Open and unscrew the big black wheel/cog thingy (make sure you get lots of towels or drain all the water first with the little pipe to the right of the big black wheel/gog). I found a few coins trapped in my pipe and its working a treat now I cleared them out and spent them on lots of sweeties. Yummy. :D
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E. 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
