Question about Pyramid Car Audio & Video
Pyramid 7band equalizer 200watt amp model#402-vl how to huck up the wires
How to huck up the wires and speackers
Posted by william on
DROPNDEAL
    Top Expert:
  • Pyramid Master
  • 2,931 Answers
Did you say "huck" up the wires?
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
pyramid 7band equalizer 200watt amp model#402-vl h - helpful-j2fqtt4x4km4a1x1cbly0mof-5-0_11.png
Posted on Feb 10, 2018
4 Related Answers
rteemon
rteemon
  • 578 Answers
SOURCE: how install pyramid 906 vl
dont use will give problem later know for bad engine noise
Posted on Jul 07, 2009
rteemon
rteemon
  • 578 Answers
SOURCE: wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Posted on Aug 07, 2009
MECP Guy
MECP Guy
  • 344 Answers
SOURCE: I have a Pyramid 403G, no wiring diagram
http://safemanuals.com/user-guide-instructions-owner-manual/PYRAMID/403G-_E
hope this helps
Posted on Jan 25, 2010
simplemitch
Mitch
  • 752 Answers
SOURCE: in car graphic equalizer installation
Better yet, DON'T install it!! The Kenwood's outputs are well over DOUBLE the power of the Pyramids and have much better audio quality.
Posted on Jul 05, 2011
Ford probe radio display not working
i was working on my stuff and then it all when a way and if all my stuff is hucked up all my spkears wires are not working at all but i did fix it my hucking all the wires right in to the back of the head unit help me....
Oct 22, 2012 | Ford Probe Cars & Trucks
Hi, The blue light temporarily comes on like it is going into protect mode and then shuts off. I do not hear the relay click. I measured the input voltage and it is at 12v and when the power is switched...
hi ill try helping .
protect is something that stops ur amp from blowing , so there is somthing melted or speacker wires touching inside box , speackers could be blown an it some times is in the speacker itself ,but there is something because i have a 600watt sony with 2 10 clarions an it hits an the voltage reads almost 13 an stays when i turn it on hope this helps a little
Jul 12, 2011 | Hifonics Brutus BX 1205D Car Audio...
Hello can u tell me how to wire in my car speackers as iv noticed its got 4 spade conectors on the speackers thanks kyle
The spade connectors are for wireing in (seires, 2 or more in 1Channell) or seperatly 1 speaker per channell,or output wires. you can hook them up straight to each output. 1 output = 2 wires. +,and a -. Make sure each one is hooked to the right one one the speaker. Possitive lead to possitive side of speaker.
Mar 06, 2011 | Orion Cobalt 93CX Car Speaker
Same HP/pavilian speackers and low soung from gx280
save your polks,go to the nearest truck stop store and purchase a set of little loud mouths their called,i guanantee you will hear those.
Jun 15, 2009 | Dell OptiPlex GX280 PC Desktop
Kdc-519 install in 93 mustang
if u have cut the factory harness, then u may have cut the power on wire for the factory amp
Jun 07, 2009 | Kenwood KDC-519 CD Player
Dont know how to huck to deck
run a remote wire from the radio or any fuse in the fuse panel
May 21, 2009 | 1990 Pontiac Grand Prix
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
What is the proper way to connect to home theater system?
Does the Sub have a Low- Level input? This is a RCA type female connector, what you need to do is run a Male RCA cable from your home theatre where it says Sub-OUT and go into the Sub woofer Line in. Unless you only have speaker wire inputs on the back of the Sub then take the Left and Right front into the Sub speaker inputs and then out of the Sub speaker OUTS back to your speakers.
Feb 28, 2009 | Omage BB08 Subwoofer
Car Audio & Video Logo
256 people viewed this question
Top Pyramid Car Audio & Video Experts
Alphanso Tee
Thomas Perkins
Thomas Perkins
Tom Chichester
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
