Question about Epson PhotoPC 650 Digital Camera
Since installing Windows 7 it does not down load my pictures from my Epson PhotoPC 650 camera.
3 Related Answers
Anonymous
  • 542 Answers
SOURCE: External Flash for 3000Z
I have a Metz Mecablitz 50 MZ5 which incorporates an automatic exposure calculation unit which mounts on top of the camera. I normally use this unit successfully on a medium format and 35mm camera which are full manual. Even with the correct aperture, film speed, lens zoom settings inputted into the unit the exposure is wrong with the Epson. The firmware inside the camera doesn't work in a linear fashion as conventional film so reciprocal calculations cannot be conducted ie: 1/60 f8 = 1/120 f6. There are look-up tables inside the camera that calculate the exposure in an Epson Digital Camera kind of way. Epson UK are currently investigating the actual values used and how the camera calculates them so I can compensate when using the flash. My advice to you would be not to buy a sophisticated flash for this camera. No information is passed to the flash which acts as nothing but a slave to the camera. Even with a guide no of 50 in my flash unit the pictures are always underexposed and the correct exposure is difficult to work out without knowing how it works in the camera.
Posted on Sep 13, 2005
Anonymous
  • 42 Answers
SOURCE: 3100z software control
I think that to use this nice camera as a "web-cam" is really a wastage!
This fine camera should take the best photos I owned, even compared with my Canon D-SLR.
Posted on Feb 04, 2008
Anonymous
  • 180 Answers
SOURCE: i've lost my installation cd for my EPSON photopc 2100Z. HELP !!!
you can try here. you have to choose photo viewers and cameras and then in the next one choose your camera and the last you put your operating system. hope it works
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84W2LhUcmWnHiUk31CNK52sUU003D
Posted on Feb 20, 2009
I have the first Epson Photo PC Color Digital Camera and I just purchased ANOTHER Camera/Computer Connector. The problem is that the download on Epsons Site isn't use with Windows Vista only Old
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Apr 12, 2012 | Epson PhotoPC 650 Digital Camera
I have Epson Photo PC 650 digital camera. It is not working. Power is not on.
To be honest I think the camera, although great in its day has given you good service, unless changing the batteries or gently pulling on the camera contacts to make them give better contact with the batteries works I think that it is what is known as 'beyond economic repair' I. Even. Time to buy a new camera. Sorry to be the bringer of bad news.
Sep 15, 2010 | Epson PhotoPC 650 Digital Camera
Epson Photo PC Mini Cable
you can use the same serial cable for the model photopc 500 600 700 it is 8pin NOT 5pin
you can see the specs here for your camera
http://files.support.epson.com/pdf/phpc__/phpc__sl.pdf
and it it at ebay just type the right name
EPSON PHOTOPC SERIAL CABLE 8 PIN
Oct 08, 2009 | Epson PhotoPC 650 Digital Camera
CompactFlash storage card
Make sure you're using an ATA-compatible CompactFlash memory card. Other cards may not work with PhotoPC 650.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
YThe colors in my picture have yellow/green color cast.
When you take pictures under certain artificial lighting conditions- such as fluorescent, incandescent, or halogen lighting, the colors in your image may take on a yellow or green cast. You can use HotShots to touch-up the colors; see Chapter 7 for instructions.
Area captured different from viewfinder area
Make sure you look straight through the viewfinder. Keep in mind that the area visible through the viewfinder is slightly smaller than the area captured in the photo. If you're taking a close-up or macro mode picture, turn the camera dial to the LCD mode so that you can use your LCD screen to preview your picture.
Windows NT 3.51
No, Windows NT 4.0 is the minimum NT operating system requirement.
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
I can't take a picture with the camera. What should I do?
The camera may be full. Check the picture counter on the display panel. If the camera displays "00" the camera is full, erase some pictures or transfer the pictures to your computer and then erase them. Another option would be to install a SmartMedia card to store more pictures. Also, when the camera is connected to your computer you can't use any of the controls on the camera itself. See Chapter 7 of the user's guide for instructions on taking pictures from you computer.
Sep 13, 2005 | Epson PhotoPC 550 Digital Camera
How long does it take to download pictures to my PC?
At 9600 bps, which is the default setting on the PhotoPC, it takes 55 seconds to download each image. If you increase the baud rate to 57600 bps, it takes 18 seconds to download a high resolution image. If you are using Windows 95, Windows 98 or Windows NT, you can download the image faster at a maximum baud rate of 115.2 kbps.
Sep 12, 2005 | Epson PhotoPC 500 Digital Camera
Open Questions:
I just bought an Epson 650 digital camera. I know, it's not new and fancy, but it's all I could afford right now. I bought this one (from ebay) mainly because my daughter has the same one- she bought several years ago, for around$350. I've noticed what big, clear, detailed pictures it takes (she sends to me). She resizes the pictures smaller, but the resolution on hers is 144. she uses one of the "better" settings, not the standard and not the BEST. What I've noticed with mine is, the resolution is 75 and the pictures don' tseem as clear and detailed. This might be partially because the scenery ones I've taken are of SNOW. I've tried using all the settings, even the very best, which only takes 3 pictures. The resolution is still 75. The picture size is big, 15"X 11". They are JPEG. I tried using he HotShots software that came with it, and now use Paint Shop Pro 7, with AQUIRE (Twain). I tried using the memory card in the USB cable that came with it, but it seemed to be clashing with my CD burner, which is in the other USB port. It's just as easy to use the camera and serial port and PSP. My daughter doesn't know much about it, she just takes the pictures and then takes them off. Hers have always been 144 resolution. I'm not saying the pictures on mine aren't good, and they're better than the Kodak DC 3200 I've had for over a year. Just that they don't seem as good as my daughter's, and it's the exact same camera. Could it be the memory (flashcard) that sets the resolution of the pictures? I have the original 8 MB one that came with the camera and my daughter once bought a bigger one. I know I can change the resolution in PSP to something higher if I want. I've been trying to find out what decides what the resolution of the pictures (when taken off the camera) might be? I can't find anything in the directions book about the settings for this. Just the "standard, better, best and extra fine". But, they all take pictures with 75 resolution.
Feb 27, 2017 | Epson PhotoPC 650 Digital Camera
Epson PhotoPC 650 Digital Camera Logo
Top Epson Cameras Experts
Steven Wander
Steven Wander
Harrie
Tony Parsons
Tony Parsons
Are you an Epson Camera Expert? Answer questions, earn points and help others
