Question about Konica Minolta DiMAGE A2 Digital Camera
A2 coin battery have low voltage
The clock works badly change batteries coin
Posted by Maciej on
1helpful
I have a clover DV0890 security recorder, it's making a audio alarm sound inside box. on screen it says hard disk error and battery error.no disk. battery inside is a pancake type, coin type
Measure the voltage on the coin cell first. If it's low replace it. That may take care of the Hard disk error too. If it doesn't, then the hard drive may be bad. Don't replace it with any hard drive. Look for one rated for CCTV video. It's built to last longer that an ordinary Hard drive.
What is it b1318 on 00 mercury cougar
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1317 Battery Voltage High Instrument Cluster Go To Pinpoint Test C . B1318 Battery Voltage Low Instrument Cluster Go To Pinpoint Test A .
A1 CHECK THE BATTERY CONDITION
  • Carry out the Battery - Condition Test to determine if the battery can hold a charge and is OK for use. REFER to Section 414-01 .
  • Did the battery pass the condition test?
Yes
GO to A2 .
No
INSTALL a new battery. REFER to Section 414-01 . TEST the system for normal operation. A2 CHECK THE GENERATOR OUTPUT
  • Carry out the Generator On-Vehicle Load Test and No Load Test. Refer to Component Tests in this section.
  • Did the generator pass the component tests?
Yes
GO to A3 .
No
INSTALL a new generator. REFER to Section 414-02 . TEST the system for normal operation
Battery operated George Nelson Ball clock running slow
Probable cause is low battery voltage, maybe the battery was not fresh or was of too low quality. For such a nice clock, extra cost in getting an Energizer Ultimate Lithium or VARTA Professional Lithium cell is justified and the AA sized battery with 3000 mAh will work for many years. Otherwise, use Alkaline batteries and don't forget to check the expiration date always. Check http://www.batteryshowdown.com/results-lo.html to get some ideas on what to buy and what to expect.
Mar 05, 2014 • Home
Amano pix-55 battery replacement how to
The Pix-55 has a simple CR-2032 coin battery. But the battery contacts are pin-point spot welded to positive and negative faces instead of being easily replaceable as they should be. I carefully broke the battery loose and soldered the leads from a single CR-2032 coin battery holder I got off Ebay, The green electronics board is marked +&- so easy to get the leads right. Before I started, mine didn't work at all and after the new battery it works great. What a shame many of these are probably thrown away because of a $2.50 battery. The next time mine goes bad I can easily replace it.
The low battery light remains on after I changed the battery,
Hello
There are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.
The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity.
Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
2answers
When you hit the starter it will click then start and the clock will reset to 12:00 2003 grand am
The clock resets because the car battery voltage/current is so low that when the starter motor is turned the + 12 drops to less than 8 volts and so the CLOCK resets.
Please have the battery checked, check the starter motor , battery terminals must be tight.
The second hand on our LaCrosse atomic clock has stopped moving but the clock continues to keep perfect time. How do we get the second hand turning again?
The manual for one of their clocks says the clock will change the second hand to two-second intervals to conserve energy when the battery voltage gets low. Perhaps your battery is VERY low.
26helpful
2answers
Clock will not keep time have to change every day
yeap....itz the main/mother board..
contact ur system admin/vendor....
Clock runs slow. Is there a button battery to change?
the cpu's in these units use extrememly little power for the clock, unlikely that low battery voltage is the cause, unless the battery is extrememly low, then yes it would be the battery, but also the unit might not use a battery but instead use a "super cap", which is a special high capacity capacitor that can hold a charge for weeks before needing to be recharged...they are usually rated for approximately .47 farads at 5 volts and they look like button batteries but are not....if yours uses super caps instead, then it might be on its way out, not able to hold a charge any longer because of deterioration....you might need the super cap changed.....also have the unit checked for bad connections....all solder joints, etc...which is always a big problem with any electronics...sometimes, solder looks good mechanically but electrically not good so it's a good idea to have the board resoldered.
hope that helps.
silvio
4helpful
3answers
Every time I bot up my pc the dte and time is
hi,
Coin-shaped batteries on most motherboards should be CR2032. Make sure it is properly installed and + is up. IF you have a multimeter or you have a friend who has a multimeter, remove the battery and check the voltage. It should read 3.0 volts when fully charged. If it reads 1.8 volts or higher is probably OK. Be very careful installing and removing coin-shaped batteries. Most of the battery holders i have seen for these batteries are quite fragile and easily broken. I ease these batteries into the holder with the aid of "tweaker" (small screw driver).
here is a video, you can see how to remove the battery or bypass bios password.
Konica Minolta DiMAGE A2 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
