Question about Audiovox D1788 7 in. Portable DVD Player
When i load a disk it says loading then it sayd no disk
Cant get it to load the disk
Posted by loganhotlips on
John Cunningham
  • Audiovox Master
  • 6,771 Answers
Take a Q-Tip and rubbing alcohol and gently clean the laser lens, allow several minutes to dry before use, if this fails! replace the player because laser assembly not cost effective.
Posted on Mar 07, 2012
Iphone froze on loading screen
Hold the home button and power button together at his stage. If this too fails connect to itunes and restore it.. its simple
Sep 09, 2012 | Apple Computers & Internet
When i load a disk it sayd loading then it says no disk
Grab a Q-Tip and rubbing alcohol, gently clean laser lens and allow several minutes to dry, if this fails! it is cheaper to replace the player.
Mar 06, 2012 | Audiovox D1708 Portable DVD Player
I downloaded fifa 2011 and i launched the game and then it stopped loading and sayd rom loading failed load rom error=-4 please reset system, how shuold i fix it
This is a non patched version. It has something to do with Antipiracy..
Solution 1: Update your r4 or card to the latest firmware
Solution 2: You will need a patched version of FIFA 2011 (not available yet)
Please give some more info about your card.
Example: Firmware Version, Card
May 24, 2011 | Nintendo DS Console
Cant load music on centon player. Says disk
If your "Hold" button is on, turn it off. The hold button write-protects the USB drive and you cannot add or delete files.
Apr 04, 2010 | Centon Electronics 1GBMP3-001 MP3 Player
How do we start playing a game on a nintendo wii. we have just bought a console but cant seem to get a game to load
get any disc in the wii and inmeadeately click on the disc or disc channel in the upper left it might say that it neads to load the data or as sayd how the game works.
Feb 10, 2010 | Nintendo Video Game Consoles & Games
2009 suburban six disk cd
you should just have to press load button and when the green light comes on load 1st disk, after it loads then press load again to load 2nd disk. etc.. continue for all 6 disks
Sep 14, 2009 | Cars & Trucks
My PS2 tells me "this disk can't be read".
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail and both lens. This is housed in the loading dock assembly(Drive). This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 28, 2009 | Sony PlayStation 2 (PS2) Console
The disk cant be read
try the disk on a different wii and load the saved file on memory card and try it from there.if the game works fine with another account then the account that your trying to load is corrupted.if the game does read on a different system then it is your wii.(doubt it but is possible)if the game doesn't work with a new account then it is the cd.
Jun 27, 2009 | D3 Publisher Dragon Blade: Wrath of Fire...
Cant load any games
hello ,
i think the game has been damaged , try to reinsert the games into your memory stick,
Aug 31, 2008 | Video Game Consoles & Games
Console won't load disk
ive da same prblm buddy sorry i cant help ya wit dis 1:(
Nov 30, 2007 | Nintendo Wii Console
Audiovox D1788 7 in. Portable DVD Player Logo
Top Audiovox Televison & Video Experts
Raj Patel
Sheldon Dedek
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
