Question about Siemens Computers & Internet
FUJITSU SIEMENS AMILO PA 1510 NOTEBOOK DC inpt socket appears to have overheated, small burnt area directly at rear of unit when viewed with bottom casing removed but circuit board appears clean and undamaged. Notebook and all applications working perfectly off battery power but when power cord inserted and electricity switched on, notebook immediately switches off. Unit will not start up with electric supply connected and not charging battery.
  • 409 Answers
The charging port has been damaged
Posted on Jun 26, 2017
5 Suggested Answers
Anonymous
  • 3 Answers
SOURCE: fujitsu siemens amilo d 7830
Sounds like you have an exhausted battery. Even rechargeable batteries must eventually be replaced when exhausted. Try removing the battery and booting the laptop while plugged in. If it works, the battery is exhausted and you'll have to get a new one. If the laptop still doesn't boot with no battery, and you don't hear the whirr of the hard drive powering up and starting to spin, then you have a boot problem.
Posted on Aug 18, 2006
Anonymous
SOURCE: MS-1036 doesnt sense power cord attached
You hit exactly on the head with don't move the unit when plugged in - there are many people with the MS-1036 having this problem if you search the web. MSI does cover the bare-bone itself, however this falls into that damaged not defective area. Many shops would replace the entire board, making it costly as looks you had done once already. Good idea is to look to Asus 17" bare-bone and move your items over, much better made. Citrus Micro - see you worked with them, so have I, always had good luck with them, they make great contact and sometimes too honest, prices are great to - like any etail store with returns, manufacturer warranty tells most etail stores how they are to handle things. Could be why you see them getting rid of selling MSI products? Looks like you found the best idea, take to walk in repair shop - hard to beat that or again, buy new bare-bone.
Posted on Sep 07, 2007
myob247
Georgia B
  • 1342 Answers
SOURCE: Compaq V5201US Notebook Will Not Start/Boot UP
Remove the power adapter and the battery. Hold the power button in for up to 60 seconds to discharge the laptop. Re-apply power and try booting the laptop.
Posted on Jul 20, 2008
Anonymous
  • 152 Answers
SOURCE: i want to restore the
You may restore it to its original settings by opening the configuration menu. Usually, this can be accessed by booting your computer while pressing F2 or delete, depending on your computer's model. It will bring you to the configurations menu. Look for the "restore to default setting", highlight using your arrow keys and press Enter, press Esc and go to the exit menu using the tab or arrow key, select save settings and exit. Reboot your computer.
Posted on Aug 31, 2008
Anonymous
  • 63 Answers
SOURCE: Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Posted on Oct 06, 2008
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
Laptop freezing
try check cpu and ram
Feb 02, 2014 | Computers & Internet
MY FUJITSU SIEMENS AMILO 2530 IS OVERHEATING !!
What is it that happens to suggest overheating?
Do not set pc on a flat surface
Be sure of adequate airflow
Listen for fan: is it coming on?
Nov 22, 2012 | Fujitsu Siemens Fujitsu Lifebook P7000D...
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
I like to receive the sound card driver for fujitsu siemens amilo si2636 for xp operating system
Here's the link to the support site http://uk.ts.fujitsu.com/support/
Select the model from the dropdown lists - and then click on the lefthand menu and choose drivers
then click on unsupported operating systems and choose XP
Then choose audio
This direct link should work - click on I accept license then a download software button appears at the bottom
http://support.ts.fujitsu.com/download/ShowDescription.asp?SoftwareGUID=E66863D4-550C-4A60-AA49-2873B76F4AD5&OSID=665F4A20-6E31-43C3-82C2-D98CE773007C&Status=False&Component=Conexant%20CX20561%20(A-MOM) NOT it is an unsupported driver so may not work
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Connecting New Amilo Laptop to Projector
You just need DVI to CRT converter ..you can buy it so easy from any PC accessories stores ..
Jun 12, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Shutting down
hi there,
You have not mentioned much about the problem.
But it indicates a strong possibility of overheating.
Thats a safety feautre employed to prevent components getting burnt.
You may try going in bios and look for details.Some bios have information about recent failures.
also some motherboards beep next time its powered on.
also you might get a mesg on the screen just after you power on,saying that system shut down last time due to thermal heating.
hope all this helps
May 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
9,349 people viewed this question
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
