Doug Scheirer Posted on Mar 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problems with JBL PSW D110
I just hooked up my surround system which has been in storage for awhile. The JBL sub is about 11 years old and is a powered subwoofer. The onkyo was purchased about the same time. I have two options to hook up in the back receiver left and right out to sub then back to speakers or RCA from sub. I have it configured with the speakers wires going from the receiver to the sub and then to the left and right speakers. I put on a dvd and set the output in the menu to dolby 5.1 I also set the receiver to dolby pro logic everything but the sub seems to be working fine. I tried setting the receiver to bypass and the sub will work with the left and right speakers but I lose the center speaker and the r and l rear speakers. So the sub does work. It just doest not pick up on anything other than bypass on the receiver. Any suggestions would be appreciated.
Owen Barnes
Level 3:
Top Expert:
  • Master 867 Answers
  • Posted on Mar 06, 2012
Owen Barnes
Master
Level 3:
Top Expert:
Answers
867
Questions
0
Helped
398796
Points
2534
The speaker level input option is designed for receivers that don't have digital output for the sub, used this way when you set to digital the speaker outputs only get the higher range outputs so won't reproduce much bass. To get the sub to work in digital mode you need to use the digital output (single RCA) from the amp to the sub
  • Doug Scheirer Mar 06, 2012
    Thanks will try to hook up with single rca. Just remembered having it hooked up and working the way it is set up now. Will try it out thanks.
5 Related Answers
ginko
Ginko
  • 19396 Answers
  • Posted on Sep 09, 2008
SOURCE: JLB PSW-D110 Subwoofer Issues
C6 must be 50V, are you sure 100 V will work?
Do you have full schematics?
Anonymous
  • Posted on Mar 29, 2009
SOURCE: How do you disassembly the JBL PSW_D110?
what i did was i stuck my hand in the port, screw driver in hand, used the blunt end of the screwdriver put it in the indent on the magnet on the back of the sub, positioned it so that the end of the screw driver was stickin out and smacked it with a hammer and it popped out, make sure u take the screws out of the front of the sub, and then take the insulation out of the box and do the same thing to th eboard just do it on theblack part of the amp not on the board
Anonymous
  • 318 Answers
  • Posted on Apr 27, 2009
SOURCE: I need schematic for JBL PSW D110, and am just new to fiding out what easiest way would be?
get connected to the following
www.glolab.com/freeinfo/info.html-11k
or
www.vitage-radio.info/heathkit/-78k
Anonymous
  • 8546 Answers
  • Posted on Nov 30, 2009
SOURCE: Recently rebuilt psw d110 subwoofer won't power up.
Look at this post:
http://www.fixya.com/support/t3533583-subwoofer_will_not_product_sound_ignore
Anonymous
  • 107 Answers
  • Posted on Jul 30, 2011
SOURCE: what is the size of
The fuse is a 250volt 1.25 amp slow blo.
First thing I would do is check C6 to see if it is bulge or blown - regardless replace it with a 10ufd 100volt Non-polarity capacitor. If the fuse blows again unplug the blue wires from the transformer and plug in unit to an outlet. If fuse does not blow then problem is on PC board. I have a service manual for this item. Probable causes on PC board are Filter Caps, Bridge rectifier (DBA), Amplifier module, or fragments of C6 even causing shorts on board if it had blown.
I have bought C6 from MCM Electronics for under .50 cents but you have to put shrink tube on one lead and bend it back along the body and solder both leads in the board.
Good luck
1helpful
Good afternoom, i need to know at about de part number of CIS53AMI. May you help me?
It is the Class D power amplifier module that JBL uses a lot in the powered sub-woofer, they are very unreliable and hard or impossible to get.
I had modified them to use linear power amp IC instead.
http://s807.photobucket.com/albums/yy352/budm/JBL%20PB-12%20mod/
1helpful
5answers
JBL sub PSW-D110 hums, and the fuse is blown
here is the manual, I am looking for a more detailed version
I have an old sub woofer I want to hook up to my computer what would I need to do ?
That would depend mostly on your computer's audio capabilities, connections and software. Assuming you already have the rest of a multichannel speaker suite defined and supported, why not a POWERED subwoofer?
You really need to be looking at this from the PC side.
1helpful
3answers
Subwoofer will not product sound. (ignore product)
Please verify that we're talking about a JBL PSW-D110 here. I'm making no assumptions.
Are you running the Ipod into its L & R RCA jacks as prescribed?
Have you tried it with something besides the Ipod? A sub isn't supposed to reproduce a full range signal. Come to think of it, is the Ipod even outputting anything within the sub's operational range? I don't expect a lot of real bass comes out of one.
Perhaps you could try adjusting the Low Pass up to 180 to see if anything anywhere near the 'real' bass region is present.
Bottom line: There's not a lot of need for a sub (and no other speakers) running off of any music sound source. You wouldn't hear anything above 180hz.
Need power transformer or replacement circuit board for psw d110
just get one from a old computer speaker system there the cheapest
JBL PSW-D110 Humming Loud
If I remember these correctly, there is a bad coupling cap in the amp section. You should see it as the top should have ballooned up. Replace the cap and you should be OK.
Dan
Another broken speaker
from my experience's, this model is not that good a lot of people have had problems with the amp going bad.
 Grubhead
Grubhead
SmartAviator
SmartAviator
