SansuiM1315 TV Logo
Question about SansuiM1315 TV
SANSUI TV MODEL SV2918 POWER SUPPLY TRANSISTROR
3 Related Answers
Anonymous
SOURCE: sansui tv sv2918
Sweetch on thr tv just one vertical line comming in center of ty screen
Posted on Jun 20, 2008
Anonymous
replace vert IC301, C432, ( D431 & R431 should also be blown)
Posted on Nov 26, 2008
Anonymous
  • 5807 Answers
SOURCE: sansui sv2918 keeps blowing k2996 mosfet. Power led flashes and ta-ta-ta sound is heard
Check the Flyback Transformer
and associated circuits.
If 2SK2996 is blown, it may take out the PWM IC and some components
that goes with it.
Let me know what you find or needs further assistance.
Posted on Sep 23, 2012
Sansui crt tv pincushion problem ,model:sv2918
It might be the power supply is going bad or that the picture tube is needing to be replaced and is starting to not work anymore. Or cascade failure were several parts don't work anymore for the power supply inside of the TV unit.
My SANSUI tv model SV2918 Av port don't want to work please help me
Make sure the Source or Input is set to the AV Port.
New television time.
Or replace the board that the AV Port is attached to.
1helpful
Sansui sv2918 keeps blowing k2996 mosfet. Power led flashes and ta-ta-ta sound is heard
that goes with it.
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
2helpful
Hi I live in Kempton Park South Africa and my Sansui TV Model SV2918 does not swith on. The product is very good and I would like it to b repaired. Do you have suggested maintenance people that I coul
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
1helpful
2answers
Sansui tv sv2918
2helpful
TV Will not fire up.
try this,hang the collector pin of the HOT then try to switch on check the voltage its 115v dc,and check also the oscillation drive at the base of HOT take your VOM at 10v ac,ther must be a flactuate at the pointer.if the two procedure are good.plyback is deffective.but if u dont have any measured voltage at the collector of HOT ur problem is in the power supply. mc44608 is use at all old model philips tv.email me for wat happend
Top Sansui Televison & Video Experts
 Grubhead
Grubhead
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
