Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Whate does code 10 error mean my maxtor is not opening I even have a new adaptor
My maxtor used to work fine. I does not open my computer says it is working fine, it has the right driver. So I went on line & did as suggested get another adaptor which I did.I worked & opened up at the store on one of the stores laptop. now I am home and it is not opening up. What should I do?
  • Maxtor Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope it helps you
Posted on Mar 07, 2012
fwadley
Farren Wadley
  • 482 Answers
SOURCE: Maxtor 3200 storage
down load
Posted on Nov 26, 2007
I had my Maxtor One Touch plugged in the USB of my computer this am. It has worked fine up to that point. I have 4 years worth of audio files saved on there.... When I went to unplug my Maxtor this am to...
Return or contact Maxtor. For a fee they have the equipment and processes (that are proprietary) to retrieve your data. Do not restore the HD because it will erase ALL information!
Jul 14, 2011 | Maxtor OneTouch III 500GB 7200RPM USB 2.0...
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable...
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: [email protected]; in NZ: [email protected]
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
All the best
Ben
Jun 18, 2011 | Computers & Internet
Hi, I can't copy or paste any file with Maxtor One Touch 4 Mini because it always informs that "This disk is write-protected" Can you help me? Thanks a lot.
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Apr 14, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
I can't get connection my maxtor ext hdd with PC , when conncted the indicator ligting on & not blinking & abeep sound. I also changed the cable What I do ?
Hi ,
Try first by connecting the drive to another USB plot .
Go and see what happens in the Device Manager and update the driver .
Connect the device to a friend' s computer to verify if it's working there .
Maxtor has been taken over by Seagate where you can find support and downloads : http://www.seagate.com/www/en-us/support/downloads/
If the drive used to work fine previously , it's probably damaged . Download and install a recovery tool from http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
If this still doesn't work , open box ( will be lost ) and connect drive inside your dektop as secundary . The chance is serious you will be abble to access your data .
Good luck !
Feb 02, 2011 | Computers & Internet
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
External Maxtor Basics 1Tb XP/Vista
its the drivers not installed on vista.. ur drive is fine
Mar 14, 2009 | Maxtor Hard Drive
Can't detect an external Hard drive (Maxtor 1TB)
im going to assume your on XP for these instructions. other wise you still need to do the same thing.
right click the my computer desktop or the start menu. go down to properties. open the hardware tab. open the device manager. Scroll down to it, remove the driver, just delete the whole entry. unplug the hard drive, then plug it in again. See if that works.
hope this will fixya....
Jan 05, 2009 | Maxtor Hard Drive
Cannot find hard drive
I got the same problem on my 3200. Found out that the adapter was bad. Changed it and everything worked ok.
Best regards
Trond
Aug 12, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
93 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Lucky
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
