Question about HHB CDR850 CD Recorder
HHB CDR 850-No laser lit up...shouldn;t there be light ie. laser
Posted by David F. Pugh on
John Cunningham
  • 6,771 Answers
YesI when the unit is first turned on the laser will emit a red light when scaning, if no beam is present it is time to replace your player, not cost effective to repair.
Posted on Mar 06, 2012
5 Related Answers
Anonymous
  • 112 Answers
SOURCE: about the HHB CDR 850 compact disc Recorder
You may need a new laser - it's a sony unit inside.
Posted on Dec 09, 2007
Anonymous
SOURCE: HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Posted on Feb 05, 2009
joeybinky
  • 6 Answers
SOURCE: HHB CDR-850 Professional loading problem
I had the same problem with mine. The manual says to unplug it from the power and plug back in. That did'nt seem to correct anything. I also was having an issue with recording. It would'nt record data for tracks and recording would scramble. I had this burner for 10 years and loved it untill last night when it crapped out on me completely. I am VERY disappointed!
Posted on Aug 31, 2010
joeybinky
  • 6 Answers
SOURCE: MY HHB CR 850 NOT READING OR PLAYING JUST FLASHING
Machine is confused. The laser lens may have dust on it. open it up and gently clean laser with a Q-tip. My recorder died last night. I wanna' cry. it was very usefull to me with my music. Now I'm screwed after 10 years of owning it. Good Luck
joeybinky
  • 6 Answers
SOURCE: need owner's manual for HHB CDR-850 Where is
what is it you need? what is reoaur cebter? I have the machine and manual. My recorder died last night after 10 years. very disappointed!
Hhb cdr-882: what mean the letter "i/p"? (On the
That is the INPUT selector button for picking the inputs on the back. The manual for that unit is here: http://www.hhb.co.uk/hhb/global/brochures/CDR882%20User%20Guide%20v1.1.pdf
May 14, 2013 | Audio Players & Recorders
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Need owner's manual for HHB CDR-850 Where is reoaur cebter?
Aug 07, 2010 | HHB CDR850 CD Recorder
Tengo problemas con el aire acondicionado esta tirando aire muy caliente aunque este en aire acondicionado.
Ok tienes que revisar si el compresor trabaja cuando activas el interruptor del aire si el compresor no se activa podria ser que le falte freon 134a al sitema,que tengas algun problema electrico.puedes comprobar el nivel de freon con un manometro si este esta bien tienes que revisar la parte electrica. Gracias
May 03, 2010 | 2002 Kia Sedona
MY HHB CR 850 NOT READING OR PLAYING JUST FLASHING CD?CDW?....
Dec 10, 2009 | HHB CDR850 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Feb 14, 2009 | HHB CDR850 CD Recorder
Dec 26, 2008 | HHB CDR850 CD Recorder
Mar 30, 2008 | HHB CDR850 CD Recorder
About the HHB CDR 850 compact disc Recorder
Aug 14, 2007 | HHB CDR850 CD Recorder
HHB CDR850 CD Recorder Logo
171 people viewed this question
Top HHB Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
