Hoover Nextra HNF 2137 Front Load Washer Logo
Question about Hoover Nextra HNF 2137 Front Load Washer
Machine wont sart
Door lock light stays flashing
Posted by Catherine Tully on
Owen Barnes
    Top Expert:
  • 867 Answers
Your door lock/latch is broken, this is a common issue with front loading washing machines and the only way to fix it is to replace the door switch.
Posted on Mar 05, 2012
On a whirlpool cabrio washer, if the machine stay in sensor mode and wont go let the water start is that from the door lock
when you close the door the door light should go out and machine should start within 5 secs,if not the door switch needs replaced,adrian,,,,,,,,,
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Door light flashing when machine put on
Suggestion: Put the machine off, try some WD40 on the machine where the lock is (not on the door). Then open & close the door a few times. After a couple of minutes try the machine
2answers
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
2answers
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Top Hoover Washing Machines Experts
W.L.
Steve F
Mike
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
