Question about Canon iR 2016i Black and White Copier
Black edges black edge at the bottom of the copied papers !!
Posted by maramermaid on
Prithi Singh
  • 372 Answers
Take out a internal report and check if it also has the same problem.If yes then u have to check the optics for any obstruction or foreign matter.have u changed ur toner recently ,if yes then it could also be a problem if it is not genuine .How much has ur drum yielded.check that also.
Posted on Mar 06, 2012
5 Related Answers
Everett Lin
  • 990 Answers
SOURCE: Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Posted on Jan 24, 2009
Anonymous
  • 67 Answers
SOURCE: canon pc920 black and white copier white streak on copy
PULL OUT THE TONER CARTRIDGE AND SHAKE IT, IF THAT WORKED A BIT BETTER THE CARTRIDGE NEEDS REPLACED.
Posted on Apr 10, 2009
Anonymous
  • 25 Answers
SOURCE: I've got a black streak running along the edges of
from witch mechine
Posted on Oct 31, 2009
Anonymous
  • 318 Answers
SOURCE: The streaks are full page on both edges top to
I suspect the drum unit might done its time.On this model you might find you can do 50000 to 90000 copies on your drum before it is done.First replace the drum.If problem sill presist the fixing unit can be the cause of the lines.
Posted on Dec 02, 2009
lahen01
Les Ahenakew
  • 63 Answers
SOURCE: The screen says the Paten glass needs to be
use isopropyl alcohol on a cloth and clean the thin strip of glass on the left side under the document feeder, if there is ink, white out or paper dust it will show up on the copies as a black line across the page. (display dirty adf message) turned to off will stop the message from coming up on the screen, like 2son said it is under additional functions.
Posted on Apr 05, 2010
Why do I get a thick black line down side of page when copying, but not when I print
Not sure, but one possibility is that your paper you are copying is not all the way to the edge of the copier. If there is a crack along the edge where light from the room can get in it will show up black in those areas. You will see the same effect if you leave the top of the copier off and try to copy something. There could also be something wrong with the scanner arm preventing it from moving all the way to the edge of the window.
Mar 12, 2015 | Canon Pixma MX452
Copystar CS-2050 cutting off edges when copying or scanning
Check your default paper size. It may have been set for A5.
Apr 07, 2014 | Copystar CS-2050 All-In-One Printer
Edges of prints are black smudged
MAY BE DRUM UNIT IS END OR LASER UNIT
JUST SEND A COPY VIE MY MAIL [email protected]
Dec 14, 2013 | Brother MFC-8460N All-In-One Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Cutting off the bottom 1/2 inch of 8-1/2 x 11 inch paper.
Notice where the metal retainer beneath the glass cuts off the view of your document you wish to copy
and make allowances on your copy. Most printers disallow some portion of the edges of any document
for handling the transport of the document through the feeder, or in the cases of contact copiers, a portion
of the sheet as you have experienced, so that the edges need not be so carefully adjusted to avoid the dark
line in edge copied formats.
Format all documents so that you do not need to copy the portion excluded.
Sometimes this can be accomplished by reducing the size of the document.
Apr 14, 2009 | Canon Office Equipment & Supplies
Paper jam at fixing unit when copying page with black border and complete tx fax function the tx report will comes out
Does the black go all the way to the very edge.ALL copiers have a void area around the edges of the copy....to prevent the copy from sticking to the fuser roller, which operates at nearly 400 degrees while copying.The void area can be as much as 6 mm all the way around, that is to say, all 4 edges.without the void area, the copy will always jam at the fuser or fixing unit.Good Luck
Mar 26, 2009 | Canon imageRUNNER 400S Copier
Photocopies with black lines from top to bottom.
Try check your paper, see whether loaded properly or not.
If yes, probably u need to adjusting your casette
Feb 17, 2009 | Toshiba 1360 Black and White Copier
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Canon iR 2016i Black and White Copier Logo
29 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
