Long delay between pages being printed
SOURCE: Lexmark X1150 only prints first page
I have an x4550, running windows vista basic on an hp dv6000t notebook. i had the same problem. i contacted online lexmark tech and here's the solution that worked for me, thanks to help from lexmark (transcript of chat):
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. It should be set to the default to "LEMF." Change it to "Lexmark." Under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
SOURCE: Lexmark E120 does not print
Check your driver is correct for your XP OS... below link might provide you some information to help resolve your issue
http://etech.maiila.com/lexmark-x4270-driver-software-download-including-for-vista
SOURCE: Lexmark 2600 not printing
I recently had the same problem. Your Lexmark printer has automatically placed itself on pause. You must go to the control panel and unpause it from there. Its' simple, just go to control panel and select printer and faxes. Select your Lexmark printer and right click it. Then select resume from the drop down menu. Your printer is now unpaused and ready to print!
Since you did not specify the operating system of your computer, I assumed that you are using Windows.
Slow printing can happen for a lot of reasons, please try to use the Host-Based or Post Script print driver (not universal). You may download this from support.lexmark.com
For further assistance, please contact Lexmark Technical Support.
Slow printing can happen for a number of different reasons. Lexmark printers are host-based printers.
Please try use the Post Script print driver or Host Based print driver. You may go support. lexmark.com to download this, or may also click the link http://bit.ly/pYTmwf
Try:
To restore factory defaults:
1. POR the machine into Configuration Mode.
2. Use the down navigation button to scroll to the RESTORE
FACTORY DEFAULTS item on the menu.
3. Press Select. The machine performs a POR.
4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
parameters back to the factory settings.
Note: Some settings are not affected: panel language, energy
conserve, paper prompts, registration margins, and page count.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
