Question about Canon PowerShot SD200 / IXUS 30 Digital Camera
What's your problem?i put a 4gb memory card in my canon SD 200 and it says error why
Posted by Taren G on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Posted on Mar 05, 2012
Testimonial: "thank you! i returned the 4 gb memory card"
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
old marine
old marine
  • 2312 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
old marine
old marine
  • 2312 Answers
SOURCE: Put new SanDisk 4GB card in Canon A620 and get Memory Card Error
The A620 came out in 2005, before the SDHC (high capacity) protocol had been introduced. The A580 came out in 2008 and is compatible with the SDHC protocol. The A620 is only compatible with the SD protocol, and maximum capacity under this protocol is 2MB.
Posted on Aug 28, 2009
Testimonial: "perfect answer - thank you!"
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Posted on Sep 03, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: just put in new san disk 4gb memory card and
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Posted on Dec 21, 2009
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I need password for sandisk 4gb micro sd memory card
i need to unlocked my 4gb micro sd memory card on asha 200 nokia phone
Aug 10, 2012 | Nokia Asha 200 Mobile Phone - Unlocked/No...
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 | Cameras
Hi, I have Canon IXY Digital PC1101, showing error for 4GB SD Memory, where as the same is working in laptop. If i put 256MB SD in camera it's working.. do i need to do any firmware upgrade to camera to...
The PC1101 uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware incompatibility, no amount of firmware changes will make it work. You need to stay with SD cards, 2GB and smaller.
Jan 05, 2011 | Canon IXY 1000 Digital Camera
I leave tomorrow HELP I have a Canon Powershot A530 and when I put in an 4GM memory card I get Memory Card Error
The A530 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it won't work there. You need to go with SD cards 2GB and smaller.
Sep 28, 2010 | Canon PowerShot A530 Digital Camera
Sd card
There are regular SD cards and high-capacity SD cards (HCSD). Some devices are not compatible with HCSD cards. It sounds like your camera is not compatible. You may still be able to purchase 2G & 4G regular format SD cards that will work fine.
I hope that helps.
Mar 20, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
Camera will not accept any memory card over 2GB. Keeps saying "Memory Card Error"
Most new 4GB and larger cards are SDHC cards (look on the card). Although they look exactly the same as a standard SD card, they are not. Unfortunately, there is no way that these cards will work with your camera, as it was designed before the SDHC format came out. As you've dsicovered, 2GB and less are standard SD cards, and will work with your camera.
There were a few standard 4GB cards produced a few years ago, most notably by ADATA (I have one that I use in my A620). Unfortunately, these are rare now, and are somewhat expensive if found on eBay.
Oct 11, 2009 | Canon PowerShot A620 Digital Camera
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon PowerShot SD200 / IXUS 30 Digital Camera Logo
220 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
