Insignia 42" LCD Flat-Panel HDTV Logo
Posted on Mar 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats the best picture settings for 42 lcd insignia tv
Whats the best combinations of numbers for the picture settings for the best picture
Level 3:
Top Expert:
  • Insignia Master 76,851 Answers
  • Posted on Mar 05, 2012
Insignia Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987242
Points
237762
Hello
55% Contrast, 35% Color and brightness to match will give you a vivid picture to your TV.
2 Related Answers
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Jul 02, 2009
SOURCE: Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Anonymous
  • Posted on Sep 20, 2010
SOURCE: Ideal Insignia 42" LCD 1080p Color settings
color settings for tv 42 in"
I have sound and picture distortion (like what happens during a thunderstorm) in my 42 inch insignia lcd tv but not during storms. started about two weeks ago, happens intermittently. driving me nuts. is...
Your probably having what cable guys call a SNR ( signal to noise ) issue. There's no way to know unless you call your cable provider. The SNR should be 32 and above with zero pre/post errors. In case you want to ask the tech what they are.
How to set 42" Insignia from 780p-1080p.(don't know if that's the problem)T.v. connected to satillite and still get snowy ,blurry picture..My old t.v. with satillite looked better than this new t.v
You may need to adjust the native resolution passthrough setting on your satellite tv box. Besides that you set 1080i on the satellite tv box not the tv. The tv just picks it up automatically. You may call the satellite tv company directly to ask for assistance in completing these two things.
The letters have worn off HD tv insignia remote.
The owner's manual and other useful downloads can be found at InsigniaProducts.com. Just search for your TV model number!
1helpful
3answers
Insignia lag with X Box
Turn game mode on and put your xbox in hdmi 3 and if that doesnt work go to picture settings then advanced setting and turn dcm off
Why is there a half second lag on my new insignia lcd tv when i play my xbox 360 in hd and not in hd also? is there a setting i can adjust on the tv to eliminate this problem?
Try setting your TV to "Game Mode" and/or turning DCM off. A copy of the owner's manual can be found on InsigniaProducts.com with additional details, just search for your TV's model number.
I have a insigni flat screen tv and don't have a picture only a dot in the middle of the screen .. do have sound though
I know of a recent recall on several Insignia models.
Check with Best Buy to see if yours is one of them.
The power supply is known to catch fire. This TV likely has a bad power supply.
2helpful
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Picture has shadowing or ghost like images
This unit is getting distortion form the video circuits, most likely capacitors or resistors causing distortion to the input or output circuits. This problem could be caused by a bad video amplifier also ,which is distorting the signal. This problem needs to be checked with an oscilloscope to follow the signal path and find the source of the distortion. Usually this is best handled by a service center. If the unit is still under warranty call this number for Insignia customer help : 1-877-467-4289. If the unit is not under warranty, you should take it to a service center and have an estimate of the problems and repair costs. You can find parts for this television at the Best Buy parts website. Just google it and put in the number of your television and it will list all available parts and prices. You can also call this number for Best Buy parts : 1-888-237-8289. Hope this helps you with your problem.
6helpful
2answers
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
