The colours on my Wharfedale 350 tv have gone wrong. Everything is green and purple. How do I fix this.
I suddenly lost the full colour spectrum on the tv. It mainly displays greens and purples now
Posted by Richard Lang on
skoljco
    New Friend:
    Problem Solver:
  • 6 Answers
The problem is AV cables or connectors on the TV, try to replace the connector shouldwork
Posted on Mar 04, 2012
I have bpl tv model FYR 21 NEPTUNE and there is a problem in its colours uniformity. due to les green colours of pictures reflects the purple colour. please tell me the solution for setting its colours
my tvs volume has been increasing suddenly on serving the channels mostly above 20th channel recently the picture disappeared it shows red line in the middle but volume is present quickly give me the solution
Sep 29, 2010 | Televison & Video
I have a Panasonic HDTV and suddenly the colours went double!
hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
Feb 02, 2010 | Panasonic Televison & Video
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Tv turns purple and green if on too long
try dusting out the inside, or maybe using a vaccum hose to get all the dust out.
Jun 25, 2009 | Toshiba 36A40 36" TV
Colour quality problem
I have never encountered an issue like the one you are describing here and I have owned a Wii for quite some time; If you have a spare TV plug it into that and see if it makes any difference.
Nintendo Customer support are really helpful when I have had issues with previous products just give them a call and they will undoubtedly identify the issue and/or replace your current console
Blazamane
Jan 07, 2009 | Nintendo Video Game Consoles & Games
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Color problem with TV
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Feb 22, 2008 | Panasonic CT-27G21 27" TV
COLLOUR DISTORTED
actually your tv set was placed near object produced magnet especially speakers, used magnet, small one to de-gauss or just like cleaning the the tv screen untill impurity colors gone. need my [email protected]
Feb 14, 2008 | Televison & Video
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
