Question about GE 27992GE5 Cordless Phone
Battery problem I have GE2.4 GHz . I am facing few problems with it for couple of months. 1) It goes to the answering machine after 2 rings, though we tried to adjust the number fo rings, it didnt work. 2) It always shows Low battery and gets diconnected after couple of minutes (7-8min). we had just repleced the battery with a new one. The phone is always in the charger. CAn any one tell me how to rectify this problem.
Posted by umaragav on
5 Related Answers
Anonymous
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Posted on Jul 07, 2007
Anonymous
SOURCE: Memory Full?
I unplugged my power supply cord from back of phone and replug it again, I found there were in fact four messages. After I deleted them I was able to use the memo button again. So perhaps this willhelp you, too. Ackey320
Posted on Sep 02, 2007
Anonymous
SOURCE: "new voice mail" display
call your phone service and have them disconnect the voice mail and if they cant just remove that have them set there rings at like 9 since most phones only have up to 5 rings for the machine to answer.you will have to use there voice mail service to hear your message and then delete it but should be good after that. i have comcast and they said it would take 3 days to deactivate voice mail but told me how to get there so i can get rid of that flashing light, hope this helps you
Posted on Nov 28, 2007
Anonymous
  • 84 Answers
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Posted on Feb 14, 2008
Anonymous
SOURCE: Answering Machine Language
Just as the other answers that were left...you just have to press the skip button. Just make sure that you press announce on the cradle...not on the phone...then when you hear the voice in Spanish just press and HOLD the skip button until it changes to English. Good Luck
Posted on May 22, 2009
Change number of rings on uniden phone model exi 8560
The EXI8560 isn't an answering machine. It will continue to ring until someone or some answering machine picks up or the caller hangs up.
To change the ring count on your answering machine, consult the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Jan 14, 2014 | Uniden EXI8560 5.8 GHz 1-Line Cordless...
How do i increase the length of ring time before it goes to answer machine?
Step 1: Determine the make and model of your phone/answering machine.
Step 2: Repost your question, being sure to include the information from Step 1.
Nov 10, 2011 | Lands Phones
The phone only rings four times then it goes into answere
Here's how to set the ring delay:
Setting the Ring Delay
The Ring Delay setting determines the number of times the machine
rings before it answers.
1 Press Menu, 2, 1. .
2 Press Z or X to select RING DELAY.
3 Press Set.
4 Press Z or X to select how many times the line rings before the
machine answers.
5 Press Set when the screen displays your selection.
6 Press Stop to exit.
Mar 05, 2011 | Brother FAX 930 All-In-One Thermal Printer
Need more rings before answering machine starts
some phones have switches on the base unit, sometimes on the back or bottom.  some phones you need to use the set up procedures to set this feature.
Mar 22, 2009 | Uniden DECT2060-2 1.9 GHz Twin 1-Line...
My phone does not ring when a call is received
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Dec 18, 2008 | Uniden TRU8885 Digital Answering Machine
We can hear incoming calls but callers cannot hear us. ditto if we ring out.
Try this. 1.Remove the battery. 2.Reinsert the battery WHILE PRESSING AND HOLDING THE STAR AND POUND KEYS. This worked on my dct 648-2. Good luck. WAGZ9
Aug 17, 2008 | Uniden 2.4 GHz Expandable Phone System...
GE Spacemaker Kitchen Phone/Radio/Answering Machine Model 26976 GE 1
I would pack it and send it to GE for repair replacement as defective
Mar 23, 2017 | GE Spacemaker 26976 Cordless Phone
I have the HP640 Fax machine and I'm trying to program the distinctive ring mode but when I follow the instruction which state to press the menu button and scroll to advanced fax and press ok and then it...
I had been confused for the past ten months on this issue and just figured it out! Get a distinctive ring from you telephone service. If you have a answering machine, set it to answer on the 4th ring. On the fax, press menue til you get to the BASIC FAX, press OK, scroll the arrow button til you get to the DISTINCTIVE RING, press OK. Call your special fax number assigned from the telephone co, the machine should read DRPD OK, then on the face of the hp640 on the left i believe is a button called Rcv. Mode/Contrast, press that til you get to DRPD Mode, press OK. It should work great!! Hope this helps.
Jun 17, 2008 | HP 640 Inkjet Fax Machine
Tg5632
Check your settings in your answering machine menu. 1) is it on? 2) number of rings? 3) is it set to take messages or answer only? If the machine is ringing and never answers look for a problem under items 1 and 2. If it answers, plays your greeting then hangs up on the caller, look at number 3. If all those settings are correct, power it down, repower it back up, wait a few minutes to call it.
Jan 29, 2008 | Panasonic KX-TG5632 Phone
GE 27992GE5 Cordless Phone Logo
43 people viewed this question
Top GE Lands Phones Experts
martin hogg
Bruce Robin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
