Question about Smeg SUK92MFX5 Dual Fuel (Electric and Gas) Kitchen Range
Power gone to main oven Smeg suk92mfx5
I have had a problem with the display just showing a single number - 1 or 4, for a few weeks but everything worked. I turned the power off then on again to reset it and i could then set the clock. The number would return after a few days. Last time i turned the power off and on again the display is off all together and the main oven wont work. Small oven and gas rings work fine. Any suggestions?
Posted by alinaughton on
5 Related Answers
douglas smith
  • 1462 Answers
SOURCE: Smeg main oven failure
problem is almost certainly the circular element. these sometimes fail with obvious damage but not always. check continuity across the element to be sure. you are right about element fixing. there is no reason why the design should'nt allow removal from the front as many do but i suppose the guys who make these things don't have to fix them.
Posted on Apr 01, 2007
Anonymous
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
Carmen Mikulic
  • 415 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
Posted on Sep 13, 2008
comike187
Michael Wilson
  • 17 Answers
SOURCE: i have a smeg range, gas burners electric ovens.
it sounds like the main oven is in timer mode on the timer please read instructions
to rectify
Posted on Jun 15, 2009
Adrian
  • 109 Answers
SOURCE: I have a Smeg A1 Oven which has lost it's power
The fuse is located behind the rear panel of the cooker. Depending what model this is, it may be an electronic card causing the problem?
Posted on Jun 16, 2009
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
What other hacks are there for the GPX D200B, manufactured in 2010?
I BOUGHT THIS 4-1-13 Hack is
hit setup
on the remote press 9 9 9 9
region 1 will come up at the top right.
use the side arrows go to 255
hit setup region free
Sep 08, 2012 | GPX D200B Player
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Honda Accord 2006 - backup fuse for CD player
You can simply remove the negative battery cable for 1 min for the same effect.
Apr 16, 2010 | 2006 Honda Accord
Chain oil leaks. repair shop. no need to repair. will start leaking again after few uses. is this true ? husqvarna 359
My 359 doesn't weep oil, one of very few that don't. But the oiler has never been turned above 3 or below 1.
Did you perhaps turn the oiler adjustment to far? It has only 3 positions. Check your manual.
Return it to the repair shop and make them stand by their work. If it stops when picked up from repair shop then starts again later something you are doing is the likely cause. Read your manual about oiler adjustment.
You can find both an Operator's Manual and an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
GL
Lou
Oct 14, 2009 | Garden
Everything works but the display window.Is there a bulb for the display that I can replace?
jenair actually had a problem with these for a few years, they go black
or very dark
goto applianceparts.com
type in your model number, your looking for the ERC
or the clock
you cannot replace just the display
Oct 13, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Memory or video Issue?
Try unplugging everything and letting it sit for a few minutes. 10 is a good safe number. Plug everything back in and try again. If this doesn't work, you have a serious issue that microsoft needs to address and fix.
Oct 04, 2009 | Microsoft Xbox 360 Console
Sony kp-53v80
Heres how you get into the service menu. BUT be very careful write down anything that you change as this can screw your set up and if you write down everything you will be able to change it back if it affects your set. You may want to consider getting the service manual which will explain all the details on the convergence adjustments. If so let me know and I will post a link where you can get one along with free tech support to help you out with it.
Put the TV in Standby Mode.
  • Then press the following buttons on the remote:
    {DISPLAY} {5} {VOL+} {POWER}
    or
    {DISPLAY} {5} {POWER}
    or
    {DISPLAY} {5} {PICTURE} {POWER}
    or
    {DISPLAY} {5} {VOL+} {PICTURE} {POWER}
  • The TV will turn on with the Service Menu displayed.
  • Use numbers {1} and {4} to select the item to adjust.
  • Use numbers {3} and {6} to adjust the value of the data.
  • Press {MUTE} then {ENTER} to save new settings.
  • The words "WRITE" in red will show up in the upper right corner if saved.
  • Turn the TV off to exit the service menu.
  • Mar 25, 2008 | Sony KP-53V80 53" Rear Projection...
    Open Questions:
    See all Smeg SUK92MFX5 Dual Fuel (Electric and Gas) Questions
    Smeg SUK92MFX5 Dual Fuel (Electric and Gas) Kitchen Range Logo
    89 people viewed this question
    Top Smeg Kitchen Ranges Experts
    Michael Thomas
    Michael Thomas
    Lee Hodgson
    Lee Hodgson
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
