2000 Ford Expedition Logo
sheri Posted on Mar 04, 2012
Lift gate will not open
Can here the lock click open but door nor the glass will open
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1163
Points
12
Check fuses they have seprate fuses
5 Related Answers
Anonymous
  • Posted on Dec 04, 2009
SOURCE: lift gate latch of 2003 Ford Escape
I just want to know if there is any manual to disarm the lift gate and check for the problem. Currently my door is lock and cant open, how you force it to open?
Anonymous
  • 10319 Answers
  • Posted on Jan 24, 2010
SOURCE: the glass lift gate on my 2008 Ford Escape keeps
you either have a weak latching device or a misaligned striker that strikes the latch which will catch it and keeps it closed securely
Anonymous
  • Posted on Apr 17, 2009
SOURCE: 3 out 4 power locks
I have this problem with one of my locks. I have been told that it is the actuator.
Anonymous
  • Posted on Jun 29, 2009
SOURCE: rear door lactch will not open but other doors do
I have the same issue on my 2002 Escape. I hear the cylinder motors engaging on the doors but not the liftgate so all I can assume is the wiring loom on the passenger side upper corner of the liftgate needs attention. That is where the wiring is for the door motor that releases the window and gate. I will post again after I solve this. 6/28/2009
Anonymous
  • Posted on Aug 13, 2009
SOURCE: rear tail gate will not open
how to i open a stuck lift garte on a ford winstar 2000 lock broken too
How to fix the lift gate glass adjar door to eliminate the flashing lights at the dashboard in Ford Escape 2005
Bridge the wires at the switch located at the door/lift gate which signals that the door/lift gate is open/adjar
I have 2005 chevy tahoe my doors all licks but my liftgate door with window stays open use to lock w all my doors? I havent check anytjing yet? I cant lock it.
Here is how it works !
Liftgate Locking Operation
The lift gate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the lift gate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The lift gate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a lift gate lock function has been received by the BCM. The BCM will then ground the control side of the lift gate lock relay. This energizes the relay and allows voltage to be applied to the lift gate lock actuator lock control circuit. Since the other side of the lift gate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the lift gate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and lift gate will unlock.
The BCM also runs diagnostics on the lift gate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the lift gate lock circuit and that the lift gate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following:
?ā‚¬Ā¢
An open ECC fuse
?ā‚¬Ā¢
An open or short to ground in the lift gate lock relay battery positive voltage circuit
?ā‚¬Ā¢
A faulty lift gate lock relay
?ā‚¬Ā¢
An open or short to ground in the lift gate lock relay control circuit
?ā‚¬Ā¢
A short to ground in the lift gate lock actuator lock control circuit
?ā‚¬Ā¢
A faulty BCM
How do I open the cargo door if it wont open?
rear door hatch lock repair GMC Chevrolet - YouTube
? 4:26
https://www.youtube.com/watch?v=QS3PMhGgyAg
Apr 5, 2014 - Uploaded by auto resource
2002 Yukon, rear hatch lock not locking. ... rear door hatch lock repair GMC Chevrolet. auto resource ... chevy tahoe lift gate notopening - Duration: 2:12. ... A Method how to unlock your car in 10 seconds :) - Duration: 0:35.
chevy tahoe lift gate not opening - YouTube
? 2:12
https://www.youtube.com/watch?v=xU6ybiY3F4I
Sep 1, 2010 - Uploaded by 76bluemoon
Back lift gate/glass would not open or release. Even when unlocked with the key fob or the unlock switch on the drivers/passenger door. ... How To Install Replace Rear Lift Gate handle 2002-09 GMC Envoy Chevy Trailblazer ...
LIFTGATE MOTOR WENT OUT. HOW CAN I OPEN THE DOOR MANUALLY?
? 2:12
Sep 1, 2010 - Uploaded by 76bluemoon Back lift gate/glass would not open or release. ... Wow, are you sure? .... known issue with tahoe, suburbans, hummers and othergmc vehicles. ... 2007-2012 Yukon Denali Rear Door Lock Actuator Replacement ... 2004 GMC Yukon XL rear liftgateremoval - Duration: 50:17. by Velvethamma 5,814 views.
How do I opened locked tailgate buttons don't work or key switch?
will glass pop open with remote or key ,whe nyou turn handle if so you may need to remove tailgate trim panel to acess handle assy so you can open it by moving lock rods inside tailgate panel
2008 Pontiac Torrent lift gate will not open
Hotnurse37. I'd you fix your problem. I have same issue. Fuse is okay. Remote will open all doors but I can't even hear the rear attempting to unlock. Did get access to emergency release after trying for a long time. Lock and latch looked fine but back to same problem after closing lift.
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
Click the link below:----
2007 Mercury Mountaineer: Liftgate will not Unlock or Open? http://whoisbyme.blogspot.in/2012/06/2007-mercury-mountaineer-liftgate-will.html
Adjust Hydraulic Lifters? http://schematicsdiagram.blogspot.in/2012/04/adjust-hydraulic-lifters.html
How to open rear lift gate? http://repairhelpcenter.blogspot.com/2011/12/how-to-open-rear-lift-gate.html
--------- Power Liftgate Shuts Down http://whoisbyme.blogspot.in/2012/07/power-liftgate-shuts-down.html
------------ Power Lift Gate Will Not Remain Open http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-remain-open.html
----------- Power Lift-gate will not Operate http://whoisbyme.blogspot.in/2012/07/power-lift-gate-will-not-operate.html
------------- Liftgate will Not Stay Up Open? http://whoisbyme.blogspot.in/2012/07/liftgate-will-not-stay-up-open.html
---------------- Rear Door will not open http://whoisbyme.blogspot.in/2012/07/rear-door-will-not-open.html
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside? http://whatisbyme.blogspot.in/2012/05/2000-toyota-corolla-rear-door-wont-open.html
These details will help.
Thanks.
Liftgate on 2005 uplander won't open
The locking mechanism on the rear lift gate for the Chevy Uplander has some plastic and rubber-coated parts that can get jammed. If you can pull back the panel from the inside top near the glass, you can reach down and try to spray some silicone lubricant into the lock. This could help get those parts unstuck so they spring back when you pull on the handle latch from the outside. Once you get the rear hatch open, I recommend taking out the locking mechanism and thoroughly lubricating it. Your rear lift gate will start to release very easily from then on.
1helpful
2answers
Rear tail gate will not open
Lift Glass opens sporadically
Give latch mechanism a good spray with white lithium grease or similar also, in case latch is sticking slightly.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
